We have some new Irem M92 PAL dumps.I dumped the registered device from a Gunforce II PCB (on ‘M92-B-G’ ROM board).This is actually present also on Superior Soldiers ROM board at same location and with same label.Then I found that this PAL is found also on In the Hunt/Kaitei Deisensou ‘M92-E-B’ ROM board with different label.I dumped also the two PALs from a genuine R-Type Leo : the one ‘marked M92-C-2L-‘ @IC7 is found also on Lethal Thunder/Thunder Blaster (same label and same location) and other M92 games too (but with different label and location).The other (labeled ‘M92-C-7H-C’ @IC43) is specific to R-Type Leo only.These dumps gave me also the chance to reorganize all Irem M92 dumps merging shared dumps and removing unneeded entries.
Palamedes (US version) and Alien Storm (bootleg, set 2) PAL dumps added
Today we have some new PAL dumps.Our regular contributor ‘coolmod’ posted on Dumping Union native dump of a PAL20L8 from a Palamedes (US version) PCB.I took care of converting it to GAL20V8 fuse map which he successfully tested on board.Thanks to him.
I dumped two PALs from an Alien Storm (bootleg, set 2 according to MAME).Devices were two secured GAL16V8 , one of them was registered too but with simple logic.A third secured/registered GAL16V8 was present but dumping was not possible due strong feedback used.
Data I/O 29A & Unipak2 repair log
I bought this setup from a good friend quite a few months ago now. I knew it needed some attention when I bought it.
On power up I got this most of the time
https://youtu.be/tzGoiafa2Wk
No response from any inputs from the keypad.
The keyboard generates an interrupt for the 6802 CPU. Using the scope I could see the /IRQ signal was being asserted.
I checked all of the ROM’s and found no issue and also checked to surrounding logic and found no issue.
Looking around the main PCB I found a couple of problem areas.
As you can see, both of these chips had some corrosion. I replaced them but they made no difference to the problem I had so after a while I came to the conclusion the CPU must be bad.
Searching eBay turned up nothing UK based so I fired off an email to my friend, Purity to see if he had a spare I could buy. He had one and said I could have it.
And now I get this
https://youtu.be/BgGFMV-0hL4
Problem solved.
Next issue was with the Unipak 2 itself.
I could successfully select and read chips but the data being read back was a little wrong.
Reading a few carefully selected addresses of an EPROM I found that bits 2, 3, 4 & 5 were stuck high.
Looking at the schematics I quickly came to a potential problem area.
You can see from the schematic above that the LM339 comparator is responsible for those exact bits.
I removed the chip and tested it out of circuit. The chip failed and I ordered some new ones.
With a new one fitted everything was back to working status.
I’m really happy to finally have this in my collection and working.
Massive thank you to Purity for his generosity. He has been very kind to me recently and also a great help. I hope one day to be able to return the favor.
Sega 171-5468 reproduction PCB
A good friend of the site, frsj8112, has reproduced the MCU bypass PCB that Sega used on some of its games and he wanted to share his work.
The PCB’s can be ordered direct from OSHpark HERE
Huge thanks to frsj8112 for creating and sharing this. Im sure it will help many people out.
Terra Cresta bootleg PAL dumps verified and redumped
Having a working Terra Cresta bootleg (from Tecfri but they are all the same) gave me the opportunity to verify the PAL dumps we had.I successfully converted from PAL16R4 to GAL16V8 fuse map two of them.The third one was a native dump from a PAL16L8, the fuse map we had was not good so I redumped the device from my board and successfully reversed it in GAL16V8.Most likely, like it often happen for bootlegs that have same layout of original, the dumps should be working also on the Nichibutsu board but a real test is needed and would be appreciated.
