A quick repair for this Sky Kid (Namco) I received some days ago :
Board was in near mint condition but it didn’t boot sitting on a semi-static garbage screen (which was looping sign that watchdog was active)
Most of the devices were socketed so for first I ruled out the many custom ICs present, they were all working.Then I tested the RAMs out of circuit.Two Mitsubishi M58725P (2k x 8-bit static RAM) failed (at different address location)
Replaced them with compatible 6116 and board successfully booted with no further issue.Job done.
A friend got a Mahou Daisakusen (japanese version of Sorcer Striker) board with faulty graphics.
It was playing fine with sound but there was an obvious color palette problem.
I started looking at signals around the color outputs of the PCB and quickly found weak signals on the 74HCT273 at location U12. Piggybacking the chip with a working 74LS273 fixed the colors immediately.
I replaced the chip… Board fixed.
Here is a picture of the PCB with the defective chip highlighted in red:
PAL UpdatesComments Off on Nichibutsu High Rate DVD System PAL dumps added
Aug202017
We have some new dumps from an unusual arcade hardware called High Rate DVD, a DVD-based mahjong system released by Nichibutsu in different volumes, you can read more about here:
256KB binary dumps have been provided by ‘system11’ on Dumping Union list, I took care of reversing them to GAL16V8 targeting devices.Each PAL (identified by a colored stripe or dot on chip) is shared among more than a volume and other Mahjong games too, you will find info on database.Thanks to ‘system11 who also successfully tested dumps back on hardware.
PAL UpdatesComments Off on Cross Blades, Multi Game III, Poosho Poosho PAL dumps added
Aug182017
New PAL dumps today.We have the ones from :
Poosho Poosho.Game was unemulated until I spotted a PCB and bought it thanks to Dumping Union donations.Game will be included in next MAME release.Device was a secured PALCE22V10 which I reversed into a GAL22V10.
Multi Game III.This is an hacked clone of the Nintendo Play-Choice system but hardware is based on the Famicom/Nes home console, you can select 21 games.Devices were three in total, I reversed them in GAL devices ( GAL20V8 and GAL22V10 replacements available for the original PAL20L8)
Cross Blades (Japanese release of Blade Master!).The game runs on Irem M92 hardware, device was a secured PAL16L8 (labeled ‘M92-D-3J-‘ @IC26 on ROM board) which I reversed and successfully tested in a GAL16V8
Received some Irem 92 boardsets mostly for replacing preventively the infamous ELNA brown electrolytic capacitors but two of them were faulty too.
The first was a Cross Blades (japanese version of Blade Master!), board had green ELNA capacitors so no strict need to replace them.
But it suffered from sprites isssue, they were missing some parts:
Pressing the board in the area of ‘NANAO GA22’ custom ASIC restored the sprites :
A closer inspection of this custom revealed three liften pins :
Reflowed them fixed the issue :
The second board was Hook (World version) :
Game booted up but sound was missing, I could hear only a rustling noise.Besides, video had some interferences:
Usually the two issues are strictly related, the cause is some bad electrolytic capacitor in audio circuit which affects video output too.The board mounted ELNA brown capacitors which are well known to age poorly.Sure enough :
The 470uF 25V @C202 was clearly leaking, this capacitor is used as filter for the +12V for the amplifier, this explained the issue.Measuring it out of circuit confirmed it was bad with an increased ESR of 150 Ohm :
I replaced this and all other electrolytic capacitors, this fixed board completely:
Here’s for reference the capacitors list with value and location :
