Oct 252017
Received this faulty Capcom CPS1 A-BOARD, actually the ‘DASH’ revision with a 12MHz oscillator in place of 10MHz one:
Board played with good graphics but sound samples were completely wrong and randomly played, here’s a video made with a Captain Commando B-BOARD/C-BOARD:
PCM samples are played by an OKI ‘MSM6295’ IC which addresses two 1Mbit devices (located on B-BOARD) and reads back their data.Judging from flux residuals the IC was previously reworked on this board as well as other components of audio circuit:
For first I tested all traces to/from it, all was OK.So, most likely, the IC was bad, no wonder since it’s a prone to failure part.I removed it:
Cleaned the PCB from flux and installed the spare:
Time to test:
Board fixed.End of job.
 Posted by at 6:49 pm
Arkanoid repair log #1
 PCB Repair Logs  Comments Off on Arkanoid repair log #1
Oct 212017
Got this original Taito (licensed to Romstar) Arkanoid PCB for repair:
Board uses the Taito Classic pinout (used on other games like Bubble Bobble, Elevator Action, Jungle King) so I had to build a proper JAMMA adapter:
On power up I was greeted by this static screen:
The string “WOVO VEM EVVOV” reminded me “WORK RAM ERROR”.I had confirm of it opening one of the program code ROM with an HEX editor:
The WORK RAM is located  @IC15 in form of a 2K x 8-bit device but piggybacking it had no changes.There are other two 2016 static RAMs @IC57 and IC58  :
When I went to probe the one @IC58 I found the data bit 2 (pin 11) stuck high:
This is tied to pin 9 of a 74LS245 @IC42 for exchanging data with the other one @IC57 which, according to MAME memory map, is the VIDEO RAM shared with Z80 main CPU:
1   1   1   0   *   *   *   *   *   *   *   *   *   *   *   0       RW  2016 SRAM@IC57
1   1   1   0   *   *   *   *   *   *   *   *   *   *   *   1       RW  2016 SRAM@IC58
 AM_RANGE(0xe000, 0xe7ff) AM_RAM_WRITE(arkanoid_videoram_w) AM_SHARE(“videoram”)
PIN11 of the transceiver was, instead, properly toggling :
Piggybacking it restored correct error message:
I pulled the 74LS245 and it failed the out-of-circuit test exactly in the involved gate:
Replacing it fixed the board completely.
 Posted by at 11:45 pm
Sukeban Jansi Ryuko (317-5021) decrypted
 Decrypted Updates  Comments Off on Sukeban Jansi Ryuko (317-5021) decrypted
Oct 212017
Hi there !
System 16B version of Sukeban Jansi Ryuko (317-5021), using a FD1089B is now available , you can grab it from the dedicated page. I don’t think a lot of people will be interested in it, as it’s a mah-jong game using a dedicated controller …
Cheers !
 Posted by at 4:30 pm
Toki double repair log
 PCB Repair Logs  Comments Off on Toki double repair log
Oct 072017
A quick double repair log of Toki, a funny and addictive platform game released by TAD Corporation in 1989.
The first PCB:
On power up it was stuck on a blank static screen:
Doing a visual inspection I noticed some scratches on solder side:
Using my multimeter in continuity check I found a couple of severed traces in the 68000 main CPU area:
After patched them the game successfuly booted:
But sound was absent, this was due missing YM3812 OPL chip and custom SIL ‘HB-41’ module:
I finished the repair installing the missing components, this restored full sound.Board 100% working again.
The second PCB:
Board booted but backgrounds graphics were corrupted and flashing :
Also here I found a broken trace on solder side:
This restored graphics:
But, while I was testing the board, suddenly I lose sound and I could no longer coin up.The two issues are related each other since on this hardware the Z80  CPU commands the sound system but also handles coins.Indeed, probing it revealed a stuck signal on CLOCK pin 6 where a 3.579545 MHz one should be:
Looking at hardware, the clock is derived by a 14.318 MHz quartz then divided by the custom ‘SEI80BU’ (which also does interface between main and sub CPU)  and lastly divided again by a 74HC74 (14.318/4= 3.5795)
I replaced the quartz  with no luck , the 74HCT74 was not receiving any 7.159MHz signal so, for exclusion, the ‘SEI180BU’ had to be the culprit.I removed it and took the spare from a scrap Raiden PCB:
This restored sound hence the custom was really bad:
Double repair accomplished.
 Posted by at 11:06 pm
‘For Sale’ Section
 General  Comments Off on ‘For Sale’ Section
Sep 242017
As you may now notice there is a new tab on the menu bar called ‘For Sale’.
At present this is just a simple gallery showing items that we may be selling at any particular time.
If your interested in any items then please contact the seller directly via the contact form
 Posted by at 6:03 pm
