Popeye repair log
 PCB Repair Logs  Comments Off on Popeye repair log
Nov 302017
Quick repair this one.
Received this board recently from a great eBay seller.
It was sold as faulty and indeed it was. On power up I was greeted with this static screen.
As the Z80 is already socketed on these boards I hooked the Fluke 9010 straight up and did a RAM test. As I was expecting, this failed.
The main RAM is located next to the 4 program ROM’s. One socket and one new RAM chip and we have a nice easy fix.
 Posted by at 8:15 pm
Punk Shot repair log
 PCB Repair Logs  Comments Off on Punk Shot repair log
Nov 272017
Some days ago I received this faulty Punk Shot PCB (manufactured by Konami in 1990)
Game had small glitches over the sprites and played mute:
MASK ROMs check reported two bad devices:
Usually jailbars mean some problem in data bus so I went to look at relevant circuit.As in many Konami PCBs the sprites generation circuit is condended in two ASICs : the ‘051960’  which generates the address lines for the MASK ROMs and the ‘051937’ which reads data.Indeed I found a missing connection beetween pin 84 of  the ‘051937’ and pin 28 of the 8Mbit MASK ROM @K7
This was caused by a broken via on solderside:
Patching it restored graphics, MASK ROMs check successfully performed now:
As for lack of sound I quickly pinpointed the fault in a 2k x 8bit static RAM @E6 (connected to Z80 audio CPU). piggybacking it restored sound.Once removed I had confirm it was really bad :
Job done.
 Posted by at 11:12 pm
Haunted Castle repair log #5
 PCB Repair Logs, Repair Logs  Comments Off on Haunted Castle repair log #5
Nov 252017
I got this board for my collection as untested from an arcade operator
Board was the typical Konami pcb manufactured in Italy ( I believe Electronic Devices had a deal with them to import the pcbs and populate certain chips in Italy).
You regognize these boards because they have sound z80 made in Italy , soldered eproms and cheap sound potentiometer
Later on, beginning of 90s they started to put also general “E.Devices” stickers on eproms in place of Konami ones, but at least the eproms were socketed
Back to this board, it booted and the graphic was OK but there was a continuous metallic sound all the time.
Ruled out DAC and OP AMPS because usually when these fails, you have at least either FM or samples working, I started to probe the sound circuit logic following the schematics.
I noticed that the commands from the main CPU were correctly sent to the sound section but as soon as the Z80 had an INTERRUPT request, the CPU didn’t aknowledge it and blocked itself
In particular:
Signal IORQ didn’t go low, thus making the INT signal from the 74LS74 always LOW.
I proceeded to desolder the Z80 and tested it on another game with a socketed CPU and it confirmed to be bad.
While soldering the same Z80 by NEC used on proper Konami assembled boards, I also changed the sound potentiometer with an original Konami taken from another scrap game.
Game was fixed without any other issues.
Contra and Pac-Eight PAL dumps added
 PAL Updates  Comments Off on Contra and Pac-Eight PAL dumps added
Nov 222017
Today we have new PAL dumps :
  • Contra.
‘coolmod’ sent in 256KB binary dump of the secured PAL16L8 from an original Contra PCB, I took care of reversing it in a GAL16V8 fuse map that he successfully tested on board.This dump replace the old archive we had.Thanks to him.
  • Pac-Eight (a Namco Medal Game)
PLDs (all GAL16V8) have been dumped by Rod_Wod of Dumping Union mailing list from this board:
We mark them as ‘assumed working’ since they have been obtained from unsecured devices.Thanks to him.
 Posted by at 9:02 pm
Nov 152017
Maybe many of you will recognize this IC and throw up hands in horror:
This is the ‘infamous’ ‘HB-41’ used on several arcade PCBs (from Seibu/TAD Corporation but not only) :
  • Raiden
  • Blood Bros
  • Legionnaire
  • Sky Smasher
  • Toki
  • Dynamite Duke
  • Olympic Soccer ’92
  • Cabal
  • Heated Barrel
  • Operation Wolf
This analog component (20 pin SIL package) is used in sound circuit to mix background music and sound FXs as well as it acts as filter of both.From my experience (maybe also others can confirm it) it’s a prone to failure part.Let’s take a look at what is inside it:
As you can see from above scan the custom is built around two ICs :  a dual operational amplifier and a quad operational amplifier.All the rest are resistors (also printed film ones, the black squares), ceramic and tantalum capacitors.In order to reproduce it, after removed the epoxy, I pulled all the parts and metered them then I drawn schematics  which then I routed  ending up in a 5.3 x 1.8cm PCB:
More or less same dimensions of original part:
Here is how it looks assembled:
I used an LM358 and LM324 for my testing which maybe are not the best solution since the original OP-AMPs have both high gain bandwith (10MHz) but the replacement works well on all PCBs I tested so far.Here is testing on a Cabal, Blood Bros and Toki PCBs:
See you all to next reproduction project!
 Posted by at 10:28 am
