PAL UpdatesComments Off on Dangerous Curves PALs added
Dec102017
Muddymusic sent me a Dangerous Curves PCB which has a load of unlocked PALCE16V8 devices on it.
I dumped them all using my programmer.
The PCB is a non worker so I cannot test these but they are assumed working at this point.
Received from Uruguay this ‘TH Strikes Back’ PCB (a.k.a. Thunder Hoop 2 by the spanish Gaelco)
Board played with all the graphics scrambled and messed up:
Doing a visual inspection I found a severed trace on solder side:
Patching it restored graphics but playing the game I noticed that the sound samples were all wrong and played randomly:
Samples are generated by the usual OKI MSM6295 PCM chip, given the high rate of its failure I went straight to replace it:
This gave me correct sound.But while testing the board, it suddenly committed suicide:
Like many other Gaelco boards this PCB uses for protection a Dallas DS5002 MCU which executes code stored in battery backed-up SRAM.When the contents of the SRAM get lost due a low battery or other problem the board will no longer boot showing on boot the “COPROCESSOR NOT READY” or “COPROCESSOR BAD” error:
Thanks to the work of MAME devs (Peter Wilhelmsen and Morten Shearman Kirkegaard) who dumps the contents of the SRAM now we can revive most of the Gaelco boards.The usual procedure to do it is well known and can be found on the net but it won’t work for some games that use a special register like Thunder Hoop 2.I was warned of this by Peter Wilhelmsen himself, he explained me how to properly desuicide this board (I will cover this topic in a proper post).I did it and board booted again but freezed everytime I started a game:
This issue had nothing to do with the Dallas DS5002 MCU, board was properly desuicided so I started to look elsewhere.Using a logic comparator in 68000 main CPU area I found a 74LS373 @D16 (involved WORK RAMs addressing) with a stuck LOW output (PIN 6).Measuring resistance to ground of this pin gave me only 10.9 Ohm sign that internal junction was almost shorted :
Once removed the TTL it failed the out-of-circuit testing in that exact pin:
Fitted a good TTL fixed the board definitively.Thanks again to Peter Wilhelmsen for his precious help.
This EPROM installs on the CPU board @ A4. This does not replace the original software but is only used as a means of testing the main-board, sound and video hardware. Detects STERN, KONAMI and POOTAN versions of the software.
Diagnostic mode is accessible by holding down player 2 start whilst powering on the game or enabling demo sounds via dip 8 of dsw2.
PAL UpdatesComments Off on 1941 : Counter Attack (Japan) PAL dump added
Dec082017
We have a new CPS1 PAL dump from the japanese release of 1941 : Counter Attack.PAL was a secured PAL16L8 located @1A on the ‘89625B-1’ B-BOARD.Dump has been successfully tested back on a GAL16V8 targeting device.Thanks to ‘robotype’ for loaning the board.
