Pooyan Diagnostic ROM
 General  Comments Off on Pooyan Diagnostic ROM
Dec 092017
This is an initial test release.
Reported to work nicely on real hardware.
http://www.ukvac.com/forum/pooyan-diagnostics_topic360411.html
This EPROM installs on the CPU board @ A4. This does not replace the original software but is only used as a means of testing the main-board, sound and video hardware. Detects STERN, KONAMI and POOTAN versions of the software.
Diagnostic mode is accessible by holding down player 2 start whilst powering on the game or enabling demo sounds via dip 8 of dsw2.
Version: $55BF
See current version for download
1941 : Counter Attack (Japan) PAL dump added
 PAL Updates  Comments Off on 1941 : Counter Attack (Japan) PAL dump added
Dec 082017
We have a new CPS1 PAL dump from the japanese release of 1941 : Counter Attack.PAL was a secured PAL16L8 located @1A on the ‘89625B-1’ B-BOARD.Dump has been successfully tested back on a GAL16V8 targeting device.Thanks to ‘robotype’ for loaning the board.
 Posted by at 11:16 pm
Some diagnostic ROMs added
 General  Comments Off on Some diagnostic ROMs added
Dec 072017
Thanks to the courtesy of ‘philmurr’ we can host all his test ROMs for arcade PCBs.They are specific for :
  • Galaxian
  • Moon Cresta
  • Mr. Do!
  • Phoenix-Pleiads
  • Scramble
ROMs have ben tested on real hardware.You can read more about on UKVAC forums :
  • Mr. Do! :
https://www.ukvac.com/forum/mr-do-test-rom_topic361108.html
  • Galaxian, Moon Cresta and Scramble :
https://www.ukvac.com/forum/test-roms-galaxian-moon-cresta-scramble_topic355745.html
  • Phoenix and Pleiads :
https://www.ukvac.com/forum/phoenix-and-pleiads-test-rom_topic360891.html
Thanks again to him.
 Posted by at 8:41 pm
Dec 072017
Received from USA this Pac-Mania ROM board (Namco System 1 hardware) for repair :
According to the owner board played fine but mute, this was confirmed once powered it up.Using my audio probe I could hear sound on the input (pin 2) of the two LA4460 amplifiers but nothing on outputs:
At closer inspection one of them was literally blown up:
So I proceeded to remove both:
and installed two new spares and some thermal compound on heatsink:
Sound restored and board 100% fixed.End of job.
Update:
After converting this board to Splatterhouse I found that voices and other sound FXs were missing:
I quickly pinpointed the fault in a bad TL084 OP-AMP, replacing it cured the issue:
 Posted by at 4:22 pm
Super Pacman PAL 1M update
 PAL Updates  Comments Off on Super Pacman PAL 1M update
Dec 012017
From time to time we get a message saying a PAL we have doesn’t work. Usually when this happens there is little we can do as we no longer or never did own the PCB. On this occasion however we found a resolution.
Kyle point out that the file we had for Super Pacman 1M didn’t work for him. He claimed the equations for the PAL didn’t include the use of input pins 5 and 6. To back up his words with a schematic showing then attached.
The strange thing about this is he also dumped the PAL in his programmer and got the same output file as the original dumper (Channelmaniac) did.
From here Kyle built the 27C020 adapter and bruteforced his PAL chip. This time he got something that did work.
His recreation is now available for download in place of the old one.
I have a suspicion the Topmax programmer has a little bug in the handling of PAL10L8 chips although the other dump supplied by Channelmaniac supplied does work without issues so who knows.
 Posted by at 2:46 pm
