World Rally 2 repair log
 PCB Repair Logs, Repair Logs  Comments Off on World Rally 2 repair log
May 052018
I got a dead World Rally 2 which upon boot showed garbage but I could hear that the monitor was hissing, meaning that there was no proper sync.
I immediately checked the two OSC on board and found the main one, 26mhz which is driving the 68k and pixel clock dead.
The 26mhz is not very common but I managed to found it on another Gaelco board and replaced it.
Game still didn’t start and was out of sync, but the 26mhz signal now was present
Near the OSC there is a 74ls74@IC29  which divide by 2 the clock for the 68k which runs at 13mhz.
The output of the flip flops was completely dead.
Replacing it I got this time a black screen with no activity.
First thing I did without much hope was to check the program eproms , normally it’s very rare that they fail but to my surprise both eproms had pin 31 not connected internally!
Replacing eproms with good ones fixed the game completely.
Last think I did, was to change the DALLAS MCU battery since it was at 2.9V , very near to suicide.
May 042018
Got this untested Konami Salamander from the UK
It was a little bit dirty, but still in good nick. No previous repair work and no broken traces.
First startup showed that the game was stuck in watchdog, so program code was not loaded correctly by the main 68000 CPU. But sometimes it would take longer to reset the watchdog and sometimes it also shouted out one of the speech samples.
So I first took out the program ROMs, shown below, and re-inserted them:
Now the game booted into ROM/RAM test. The screen is a bit garbled, but I could see when comparing to the test screen in MAME, that ROM6 was reported as BAD
I first verified the EPROMs against MAME and they were ok. So unfortunately there was a fault in one of the MASK ROMs. I had a Salamander board since before, so I just stuck the MASK ROMs from that pcb into this one to see if it booted up and sure enough it worked. The MASK ROM printed with 6108 was indeed not working.
As this is a MASK ROM, 1Mbit 28-pin, and not a standard EPROM, I remembered that system11 made a blog post about converting Salamander to the japanese version of Life Force. I have made that conversion as well, and still had some of the pcbs and flash roms.
So I just made one with the Salamander ROM.
And voila, the game is resurrected from the dead 🙂
No other issues, job done!
Battletoads MAME PAL dumps tested.Hotdog Storm PAL dump added.
 PAL Updates  Comments Off on Battletoads MAME PAL dumps tested.Hotdog Storm PAL dump added.
May 032018
After my repair of Battletoads I have tested (after converted them from binary to fuse map) all the PAL dumps from MAME set and I can confirm they are good.All .JED must be burned onto GAL20V8 or PALCE20V8.
‘coolmod’ sent in 256KB binary dump from a Hotdog Storm, I reversed it into GAL16V8 and he successfully tested it on PCB.Thanks to him.
 Posted by at 10:22 am
Battletoads repair log
 PCB Repair Logs  Comments Off on Battletoads repair log
May 012018
Got from South Korea this Battletoads PCB for repair:
Board had a strange fault, it booted up but then always crashed after some time (going to a black screen) on title screen just before entering the attract mode :
But if you were quick enough coining up on title screen, you could start a game and play normally but sound was missing at all:
With these premises I started my troubleshoot.Since there was no sound during game I focused on the audio circuit.Hardware uses an audio DSP marked ‘BSMT2000’ , chip’s acronym stands for “Brian Schmidt’s Mouse Trap” from name of his designer:
This is a special masked-rom version of a Texas Instruments TMS320C15 digital signal processor, here’s pinout:
When I went to probe it I found that many data/address lines were either silent or stuck so chip was most likely bad.I removed it:
The BSMT2000 is not often used on arcade hardware (it can be found on many pinballs instead) but luckily I found a spare chip on a Police Trainer PCB :
With a good chip installed the game no longer crashed on title screen but sound was still missing.Probing again the BSMT2000 DSP revealed that pin 20 (data line D6) was stuck low, checking with multimeter it was almost shorted to GROUND :
I traced back this data line to pin 17 of two 74LS374 (used for data latching), these inputs were shorted to GROUND also after cuting their traces to the BSMT200.I desoldered the two TTLs and they failed the out-of circuit testing in same gate:
Replacing them restored sound.Repair accomplished.
 Posted by at 9:37 pm
Prehistoric Isle in 1930 repair log
 PCB Repair Logs  Comments Off on Prehistoric Isle in 1930 repair log
Apr 292018
Received from Germany some faulty boards to repair.There was this Prehistoric Isle in 1930 PCB, an horizontal  shoot ’em up game developed by SNK and released in 1989.
Game boots up but some foreground graphics had vertical lines through them:
Relevant GFX data are stored in a 2Mbit MASK ROM located on video board:
I dumped the device and it was good.The data of the MASK ROM are read by the near custom silkscreened ‘SNKCG’.A visual inspection in this area reveleaed some corrosion on a trace :
Trace was connected to pin 17 of the custom, it  was silent when I put on it my logic probe so either it was a dead output or an input not receiving any signal
I was not able to find where this pin was connected to so the trace was really broken due corrosion.Looking at the other near pins, they were all connected to data lines of the MASK ROM, I found corrispondance for all of them except pin 26 (D6).I run a jumper wire and foreground graphics were restored:
Happy with result I was about to close this repair when, during testing, I noticed that voice samples were missing, I could hear only some crackling noise instead of them:
Looking at sound section on CPU board I quickly found the culprit:
The 640MHz ceramic resonator (which provides clock the uPD7759C speech synthesizer IC) was missing, this a common issue on all boards that use it, it’s very easy that it comes off
I took the spare from a dead Sega System 16B motherboard:
Repair finally completed.
 Posted by at 10:06 am
