Bought this game for personal collection with a problem on the RED colour which was completely missing.
Checking the schematics there are some 74541 chips which are sending the colour bits to a resistor network for Dac conversion. The one on the red colour @UC4 was correctly working so I checked the 74ls07@UA4 involved in the blanking circuit.
Pin 2 was always below 0.5V and muted the total red colour
Another faulty board from the “portughese” box, a Flying Shark (by Toaplan/Taito)
It booted up, game was fully playable with sound too but colors were completely wrong:
By shortcircuiting some address/data pins and observing the changes on the screen I was able to figure out the palette RAMs and consequently all the remaining colors circuitry:
The data bits from the two 6116 RAMs (2k x 8-bit devices) feed into two 74LS245 and being latched by two 74LS273 whose outputs are tied to three separate R2R resistor ladders (one for each RGB color) for the analog conversion.I found nothing abnormal until I probed the 74LS273 @27N, a couple of outputs were stuck low:
This was confirmed also by logic analyzing:
I removed the IC and tested it out-of-circuit, it totally failed:
PCB Repair Logs, ReproductionsComments Off on Vigilante repair log and Irem ‘RGLD8M472J221J’ – ‘RGSD10L471G’ reproduction
Aug152018
Got this Vigilante PCB (by Irem) in a trade some years ago:
Board was dead, stuck on a purple static screen:
As usually I started my troubleshooting with a visual inspection and noticed severe corrosion in some areas, especially around the 3.579545 MHz oscillator:
Analyzying the main Z80 CPU revealed no clock on pin 6.This signal was present on oscillator output but then was lost when routed to the inverter (a 74LS04 @IC30) :
Replacing the TTL restored clock on Z80 but board was still dead.Probing the /RESET pin 26 with an logic analyzer showed an unhealthy signal, there was no proper transition from LOW to HIGH but only some oscillations :
/RESET signal is generated by the MB3771 voltage monitor @IC31.I promptly replaced it:
In this way proper signal was restored:
But main Z80 was still inactive, data/address busses were silent as well as control lines.This lead me to think the CPU was faulty so I removed it:
Testing it in another board confirmed it was really bad.With a good CPU the board finally booted up but the sprites were mostly absent, I could see only some parts of them randomly flying over the screen:
After some time spent to check different things I pinpointed the fault in a bad interconnect ribbon cable.For safety I replaced both of them:
Board fully working again and a quite enjoyable game added to my collection.
The repair was accomplished but, as always I do, I visually inspected the board looking for some candidate parts for a reproduction and I spotted two possible ones.The first is marked ‘8M472J221J’ (‘RGLD8M472J221J’ on manual parts list)
It’s nothing more than a custom resistor network used for inputs, you can find it also on other Irem hardware like M72, M92 and M107.Here’s snippet from R-Type schematics:
I reproduced it this way :
The latter, marked ’10L471G’ (‘RGSD10L471G’ on manual parts list) is interesting since it’s a R2R resistor ladder used to convert to analog the 5 palette digital bits outputted by the surface mounted ‘KNA91H014’ custom.You will find always three of them (one for each RGB color) coupled to one custom.
Its implementation on schematics:
From my experience and other references too the original part is not really reliable (it will crack or burn) so I reproduced it as well:
Testing both reproductions on the repaired Vigilante PCB:
