Block Block PALs
 PAL Updates  Comments Off on Block Block PALs
Aug 272011
A guy emailed me to let me know the Block Block PALs I had didnt actually work.
I do however have a non working board so I spent the day repairing it and then dumped mine and tested. These now work fine for me.
They are labelled
CHR-CW
CW-P
Repair log to follow
 Posted by at 4:15 pm
Golden Axe PLS153 dump
 Downloads, PAL Updates  Comments Off on Golden Axe PLS153 dump
Aug 242011
I dumped the PLS153 off Golden Axe tonight with the view of converting it to a GAL.
Due to the PLS have a higher number of output pins than a GAL it is not possible to fit this onto a 16v8 device so ive just uploaded the PLS JEDEC file.
It is probably possible to fit this onto a GAL22V10 device and make up an adapter for it but for now this will have to do.
EDIT: I have now made this adapter and can confirm it works no problem. Download and instructions are available.
 Posted by at 7:32 pm
Rainbow Islands PALs
 PAL Updates  Comments Off on Rainbow Islands PALs
Aug 212011
Added 2 RI ones.
B22-05 – this one is available from Macro’s site
B22-06 – dumped by me this morning.
According to the MAME source, these are the same for Rainbow Islands Extra too.
I think ive just about come to the end of PALs I have available to dump and test.
Feel free to get in touch if you have any I can add to the collection. Credit will be given.
 Posted by at 2:09 pm
Robocop, Irem and Time Pilot PALs
 PAL Updates  Comments Off on Robocop, Irem and Time Pilot PALs
Aug 202011
Its been another fun day of PAL goodness.
Added:
Robocop PY-0 and PY-1
Irem M81 PALs
X-Multiply PAL (M81 version)
Tested:
Bomberman PALs
Also, a user called MrDo very kindly sent me his dump of a Time Pilot PLS153 IC. With this file you can replace the PLS with a GAL16v8. Thanks go to him.
All the downloads can now be found in the Download section and are located in a new searchable table.
 Posted by at 3:12 pm
ABI Boardmaster 4000 fan replacement
 Mods  Comments Off on ABI Boardmaster 4000 fan replacement
Aug 192011
Been using my new favorite toy a lot and I just couldnt deal with the noise the fan made so decided to sort that out.
This is the stock fan
After doing some searching of the stock fan, I came up with this info:
Noise Rating:33.5dB
The fan is 60x60x25mm, 12VDC and finding a silent replacement was a doddle.
I ended up ordering this little fella from QuietPC.com
The original is “hardwired” into a power connector so I had to do a little bit of splicing to wire it in but other than that there was no problems. The new one even came with rubber mounts so I didn’t have to fight on getting the lower bolts back in.
This is the end result and it runs at 15dB so nice and quiet.
 Posted by at 7:47 am
