Jan 202013
Quite a few weeks ago I took part in a charity event which saw me win a personalised copy of Pac Manic Miner Man written by Jim Bagley and runs on original Pac-Man hardware.
My good friend Equites from the J+ forums hooked me up with an original Pac-Man board and after making up a jamma adapter it was clear some repairs were needed.
The board has 2 daughter boards for the custom chips, one of them being a 3rd party one.
A quick inspection revealed this
I reseated the the sub board and the game booted to random garbage on screen
The boards watchdog was also “barking” so I check the 4 program ROMs, all of which were recognised by MAME.
This was the ideal time to hook up the Fluke 9010 and see what was going on.
First off it showed me that the RESET line was active so I told the Fluke to ignore it.
I carried out BUS and ROM checks. All of which returned OK. I tried to carry out RAM tests and DIP switch tests but I couldnt read anything back other that “F7”.
Something was wrong at address line 14 and it pointed towards the 3rd party sync bus PCB. Equites confirmed that the previous owner of the board had this module plugged in backwards so that confirmed my suspicions.
Andyman from the J+ forum also showed me a picture of what his look like without the Sync Bus PCB attached and it was identical.
I spent quite a bit of time wondering the best way to tackle this. I could buy another 3rd party module, or, as the schematics for a TTL version are available I could build my own. My saviour came in the form of the fantastic reprogrammable device from FPGAARCADE.COM.
I have a spare here that is currently programmed with the Commodore 64 PLA replacement but I do have the tools required to reprogram it. What I didnt have was the code to program it with. A quick email to Mike, the owner of FPGAARCADE and he sent me the file required.
Once I had the chip reprogrammed (took ages as my current programmer didnt want to bother working) I fitted the device and….
As all the RAM chips are socketed I pulled them and tested them. The 2114 RAM at position 4R can back as failed. I have some spares of these so fitted a new one and fired the board up again.
SUCCESS!
This game will sometimes be running Jim Bagleys Pac Manic Miner Man so now was an ideal time to try the ROMs out on the actual hardware.
Very happy to get this running.
Thanks to:
Equites for the PCB
Mike at FPGAARCADE for the Sync Bus program file
Andyman for help diagnosing
Jim Bagley for creating PMMM
 Posted by at 6:55 pm
Contra and Cads and Dinos bootleg PALs
 PAL Updates  Comments Off on Contra and Cads and Dinos bootleg PALs
Jan 102013
I added PAL dumps from a bootleg Cadillacs and Dinosaurs and bootleg Contra.
Both are untested and they were not dumped by me, just some ive got in a big pile of unsorted PAL dumps.
 Posted by at 5:54 pm
Aqua Jack, Power Spike and SFII bootleg PALs
 PAL Updates  Comments Off on Aqua Jack, Power Spike and SFII bootleg PALs
Jan 082013
Today I have added some more PAL’s.
First up is a .RAR file with PAL’s from a Street Fighter 2 bootleg board. There are quite a few of them and a picture is included in the archive and here of their locations.
sf2bootleg
Next up, Andreas has sent in some dumps from 2 different boards.
First is Aqua Jack.
The board was not working but the PAL’s were not security locked so they are assumed working
Second is Power Spike
These are all PEEL18CV8 devices.
Thanks to both of these guys for helping out
 Posted by at 1:50 pm
Psycho-Nics Oscar PLD dumps
 PAL Updates  Comments Off on Psycho-Nics Oscar PLD dumps
Jan 012013
Andreas is back again with more dumps from his Data East Phycho-Nics Oscar board.
Chip located at F18 is a CK2605 chip which is quite uncommon and has been dumped as a PLS153 chip. This is fine and the dump can be converted to true PLS153 format by using Charles MacDonalds PLAD.EXE tool. I have already done this.
Chip located at F20 is a PAL16L8. This will need converted to a GAL first if you are going to be using such a device.
Thanks once again to Andreas
 Posted by at 9:49 pm
Magic Sword, Punisher and misc CPS1 PALs
 PAL Updates  Comments Off on Magic Sword, Punisher and misc CPS1 PALs
Dec 312012
Steve Rice has sent me a few CPS1 files that were missing.
Among then are ones for Magic Sword and The Punisher.
These were not dumped but reversed by himself and have been fully tested by him too. They are in GAL16V8 format.
Big thanks to Steve
 Posted by at 6:50 pm
