Bubble Bobble 2 prototype PALs
 PAL Updates  Comments Off on Bubble Bobble 2 prototype PALs
Aug 182013
Ive now added all the PAL dumps I took from the prototype Bubble Bobble 2 and Taito F3 motherboard.
I know that these may be completely useless to everyone else in the world but they are here anyway and muddymusic may require them at some point in the future.
The PALs I took from the motherboard may actually work on a normal f3 motherboard so would be interested in testing that theory.
Also, the two PAL20L10 chips on the second PCB of the ROM board didn’t seem to dump properly so I recreated them myself. As a result these are for GAL22V10 devices and I have tested them.
I haven’t tested any of the other as I didn’t really want to keep powering this board on and off needlessly.
 Posted by at 2:04 pm
Dumping Taito F3 Bubble Bobble 2 prototype
 General  Comments Off on Dumping Taito F3 Bubble Bobble 2 prototype
Aug 162013
Well its been a very exciting couple of days in the geek world.
dsyde and muddymusic sent me a prototype Bubble Bobble 2 (Bubble Symphony) PCB to dump.
Its been really fascinating seeing this game as its date is nearly a whole year before its actual release and there is a lot different too.
The main thing for me is the music. At this stage of development they were using an orchestral version of the original BB theme music and I love it.
Support for this game has now been added to MAME thanks to Haze and should be in the next release.
Thanks so much to dsyde and muddymusic for allowing this to happen. You’ve made this geek very happy.
 Posted by at 9:10 pm
Super Pac-Man PAL dumps
 PAL Updates  Comments Off on Super Pac-Man PAL dumps
Aug 012013
channelmaniac from arcadecomponents.com very kindly send in 3 dumps from a Super Pac-Man PCB.
They look like good dumps from unlocked chips. I will get round to converting them to GAL format but if anyone can test these it would be appreciated.
Thanks to channelmaniac
 Posted by at 7:22 pm
Namco System 2 PLDs
 PAL Updates  Comments Off on Namco System 2 PLDs
Jul 312013
caius and robotype sent me 4 more PLDs from a Namco System 2 board, in this case it was Ordyne.
Three of them are already in GAL16V8 format and have been tested. The forth is from an unlocked PAL12L10 and as of yet we have yet to convert it and test it.
Thanks once again to caius and robotype
 Posted by at 7:10 pm
P-47 Freedom Fighter repair log
 PCB Repair Logs, Repair Logs  Comments Off on P-47 Freedom Fighter repair log
Jul 282013
Got this fairly cheap from eBay.
Didn’t really know what I was getting but was described as have a chip missing. How bad can it be??
Answer: Very bad.
On getting the board and doing my visual inspection I quickly located the missing chip.
Yes that’s right, an 82S131 PROM. NOTE: the above picture was taken AFTER cleaning up. The chip was forcibly removed and had several legs still remaining in the board. It was also a mess underneath.
Now as my programmer supports this chip I wasn’t too concerned but after paying over the odds eBay prices several times trying to find one that was actually blank only to find they were all used it became clear that I wasn’t going to obtain one easily.
Enter Steph at HobbyRoms. My savior. In a little over a week I had the new chip in hand and already programmed with the correct data too.
Back to the visual inspection. There was a bit of damage to several changes underneath that would obviously need cleaned up and patched.
I fitted the new PROM and patched the 3 broken lines and fired it up to test.
A green screen. All was not lost at this point as the game could be coined up and played blind.
I probed the newly installed PROM and found the chip enable pin was not connected to anything. This pin is grounded (enabled) constantly and it looks as though it picks this ground up via a ground plane in the middle of the PCB. As this was one of the holes that was badly damaged from the old chip removal I found it had not made a good enough contact when I installed a new socket. A lot of solder later and that has now been sorted.
Fired it up for another test.
Getting better but not quite there.
Whilst probing around the patches I made I found an additional 2 pads that were unconnected that I originally missed. Patching these fixed all issues and the game is fully playable.
I actually really like this game and think its very good for its age. As an added bonus it was also an undumped version so its now added to MAME.
Massive thanks to Steph at HobbyRoms. Without his help this board probably wouldn’t have been fixed.
I would also like to add a note to any sellers of bipolar devices on eBay. At least put in a little effort to check your goods before selling at an inflated price. I get the impression most of them don’t even know what they are selling.
 Posted by at 5:14 pm
