Captain America and the Avengers PAL dumps added
 PAL Updates  Comments Off on Captain America and the Avengers PAL dumps added
Aug 132014
After the repair I decided to dump the PAL on this PCB.There where four PAL, I could dump and reverse only three of them since there is one registered device (a PAL16R8).All dumps are tested and working in a GAL16V8 except for the one marked ‘TS-002’ for which I had to use a GAL18V10 as targeting device.
 Posted by at 1:55 pm
Captain America and the Avengers repair log
 PCB Repair Logs, Repair Logs  Comments Off on Captain America and the Avengers repair log
Aug 122014
My friend Silvio kindly donated me a couple of faulty boards, this ‘Captain America and the Avengers’ was one of them:
Captain_America_PCB
I was expecting some boot troubles but when I fired up it I got this:
Captain_America_issue
All was OK except for sprites that were all missing.Since I already worked in the past on similar Data East hardware I knew that sprites are generated by some ASIC, in particular the one marked  ‘DATA EAST 52’:
DATA_EAST_52_ASIC
Infact, when I firmly pressed this ASIC, sprites were restored.Proving the tightness of the individual pins with a needle as I usually do confirmed that some pins were lifted.So time was to do a reflow of this chip and this was enough to fix the board completely.
Captain_America_fixed
Thanks again, Silvio!
 Posted by at 10:43 pm
Fluke 9000A-68000 POD PAL dump converted and tested
 PAL Updates  Comments Off on Fluke 9000A-68000 POD PAL dump converted and tested
Aug 122014
Today I disassembled the original PAL16L8 dump (made some time ago by Porchy) from Fluke 9000A-68000 interface pod and I recompiled its equations into a GAL16V8 targeting device.I can confirm it perfectly working as replacement.Original file has been removed from database.
 Posted by at 6:22 pm
Fluke 9000A-Z80QT interface POD PAL dump added
 PAL Updates  Comments Off on Fluke 9000A-Z80QT interface POD PAL dump added
Aug 122014
Today I dumped the only PAL present on my Fluke 9000A-Z80QT interface POD.Original device (a PAL16L8) was secured.Dump has been tested succesfully in a GAL16V8 targeting device.Just a technical note :’QT’ stands for ‘Quick Test’ since this POD can perform quicker RAM/ROM tests than normal Z80 one
 Posted by at 1:53 pm
Konami GX type 1 motherboard PAL dumps added
 PAL Updates  Comments Off on Konami GX type 1 motherboard PAL dumps added
Aug 112014
Today I dumped the two PALs from a Konamy GX type 1 motherboad (running Lethal Enforcers II, repair log of this will follow later), both dumps are tested and working in a GAL16V8 targeting device.Just for reference, there are actually 2 revisions of GX motherboard, they are totally interchangable and the Version 2 motherboard is just smaller and runs cooler.Games that run on this system are :
  • Daisu-Kiss
  • Dragoon Might
  • Gokujyou Parodius / Fantastic Journey
  • Golfing Greats 2 / Konami’s Open Golf Championship
  • Lethal Enforcers II: Gunfighters
  • Racin’ Force
  • Run And Gun 2 / Slam Dunk 2
  • Rushing Heroes
  • Salamander 2
  • Sexy Parodius
  • Soccer Superstars
  • Taisen Puzzle-dama / Crazy Cross
  • Tokimeki Memorial Taisen Puzzle-Dama / Crazy Cross 2
  • Tokkae Puzzle-dama
  • Twin Bee Yahhoo! / Magical Twin Bee
  • Vs. Net Soccer
  • Winning Spike
 Posted by at 10:26 pm
