Kuri Kinton PAL dumps added
 PAL Updates  Comments Off on Kuri Kinton PAL dumps added
Sep 222014
Some days ago I dumped the two PALs from an original TAITO Kuri Kinton PCB.Board is faulty (it shows graphical problems) but I can say both dumps are good and working in a GAL16V8 targeting device.
 Posted by at 10:55 pm
Sep 212014
Another one of Ben’s boards.
Had the usual graphics issues you normally get associated with those four 2114 RAM’s only this time the RAM’s had already been replaced and all four were good.
IMAG0908
Following the inputs and outputs from these RAM chips I found some broken traces, probably a result of desoldering them originally.
Pin 1 of the RAM at location 3H was not connected to anything. I patched this and it fixed the solider sprite on the title screen but some in-game graphics were all messed up.
IMAG0909
IMAG0910
After confirming all other connections were good I noticed two other 2114 RAM chips that had been worked one and socketed so I checked those too.
Initially I found pins 3 and 4 of the RAM chip at 1B. Patching these gave me this result
IMAG0912
Getting there but not quite.
A little further inspecting these chips and I also found pin 15 of the same chip not connected to GND like it should be.
Patching this one gave me a perfectly working game.
IMAG0913
IMAG0914
Boot Camp PAL entry added
 PAL Updates  Comments Off on Boot Camp PAL entry added
Sep 212014
Added Boot Camp entry to the PAL archive.
This is the same one as Combat School that Caius has already dumped.
 Posted by at 1:16 pm
Atomiswave -> NAOMI: Metal Slug 6
 General  Comments Off on Atomiswave -> NAOMI: Metal Slug 6
Sep 202014
Its a little known fact that I’m a big Metal Slug fan. Its little known because ive only recently got into playing it on a friends Neo Geo CD system.
It came as a great surprise when Darksoft announced that Metal Slug 6 has been converted to the NAOMI as I had never played it before and had also seen nothing of it.
Im happy to say it works perfectly and have had a fun morning shooting aliens.
Thanks to Darksoft for continuing with this project and for once again introducing me to more hidden gems from a system I’m likely never to own again.
IMAG0900
IMAG0901
IMAG0902
 Posted by at 2:04 pm
PLD Archive update
 General  Comments Off on PLD Archive update
Sep 132014
Just a quick note.
The PLD Archive has now been split into two, A-M & N-Z.
This needed to be done as the table was becoming slow and unresponsive for us when we are updating it and we were fearful of a database crash.
Nothing else has changed and all the entries should still be present but you will need to select the table you want to see from the page.
Thanks
 Posted by at 12:37 pm
