705 entries!
 General  Comments Off on 705 entries!
Dec 242014
Today we passed a milestone. Over 700 entires are now in the archive.
There are most likely more dumps than entries as some unknown ones are in ZIP files as a set.
Thank you everyone who has contributed over the past 3.5 years that this project has been running.
Please keep submitting them if you have them.
 Posted by at 8:19 pm
Enforce PAL dumps added
 PAL Updates  Comments Off on Enforce PAL dumps added
Dec 242014
Ive added a set of 10 PAL dumps from Taito Enforce.
They are all in their original format right now and are untested so please test them out if you can.
 Posted by at 8:15 pm
Air Buster : Trouble Speciality Raid Unit repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Air Buster : Trouble Speciality Raid Unit repair log #1
Dec 242014
Bought this mint original Kaneko Air Buster PCB from my friend Corrado:
Air Buster
PCB was working fine but sound samples (drums, bass line, etc..) were played sometimes randomly other times in a bad way:
In this PCB (and a lot of other  similar audio hardware) samples are played by the OKI MSM6296 chip which take DATA directly from the ROM that I dumped as good.Connecting an external AMP to pin 36 of the OKI6295 (this pin is the digital-to-analog converted signal fed into the UPC324 OP-AMP, you can download its datasheet here in the downloads section ) I had the same issue so this convinced me to replace the chip (with a rebadged one but it’s the same):
MSM6295_replaced_
This restored fully music/FXs.Job done.
 Posted by at 11:33 am
Choplifter PAL dumps added
 PAL Updates  Comments Off on Choplifter PAL dumps added
Dec 232014
We have had a zip file for Choplifter in the archive for a while now and I finally got the chance to test them.
One of them was a CK2605 which I dumped myself as a PLS153 and is assumed working but the other two were from a PAL16R4 device and they both work fine.
 Posted by at 7:58 pm
Super Hang On (317-0034) added
 Decrypted Updates  Comments Off on Super Hang On (317-0034) added
Dec 232014
A bit late posting this one but here it is.
Runik has been working really hard to get this done. It is partially tested right now by muddymusic and the game boots but his board set has a graphics fault so at this point it still needs further testing. If you are able to test then please let us know.
Thanks to Runik and muddymusic.
 Posted by at 12:53 pm
