May 272015
Konami do always great games and one of them is, indeed, The End.Manifactured by Stern electronics, it was released and licensed by Konami in the far 1977.Game itself is a mixture of Space Invaders, Galaga and Phoenix.I got this board from same previous repaired boards batch and it was really in excellent shape (I could say ‘NOS’ using an Ebay terminology) for a piece of hardware with nearly 40 years on the back:
The_End_PCB
It came with its JAMMA adapter from Konami classic pinout (-5V required), it played fine but there was no sound at all, I could only hear some faint rustles coming out from the speaker.
Digital audio circuit is made of a Z80 CPU and a AY-3-8910 sound generator.Code ROMs were good but when I probed the two 2114 RAMs I found that address line A7 was stuck high on both.Studying a bit the hardware I could figure out that Z80 addresses the two 2114 through four 7408 quadruple AND gates.And I could trace the stuck address line back to PIN6 of the 7408 @IC41 (a Mitsubishi M53208P to be exact).I probed inputs and they were toggling fine while its output was, indeed, stuck high.So, without hesitations, I desoldered and tested it out-of-circuit:
7408@IC41_failed
It failed miserably.Fitted a good one  and I was able to restore the sound to this “aged” board.
 Posted by at 4:36 pm
Lethal Enforcers repair log #3
 PCB Repair Logs, Repair Logs  Comments Off on Lethal Enforcers repair log #3
May 242015
Another repair from the same PCB batch of previous logs (three in a row…), this is a Lethal Enforcers PCB in mint condition:
Lethal_Enforcers_PCB
Once powered up I got this static screen:
watchodog
and a ticking sound sign that board was watchdogging.In these cases first thing to check is the main CPU.Probing pins of the HD63C09E CPU (6809 compatible) I noticed that R/W (PIN32) was completely silent.This is  the control line through which CPU decide if write (active LOW) or read (HIGH) DATA onto the DATA bus.The fact that it’s an output and  it was inactive made me very suspicious.HD63C09E datasheet says that R/W line can be made in high impedance  if BA (PIN6) is HIGH but this was not my case since BA was pulsing LOW.
/WE line of 6264 WORK RAM stuck high.This is generated, indeed, by the /WR signal (PIN32) of main HD63C09E CPU through the BUS master arbitration circuitry.This lead me to desolder the CPU from board and try it in another board.It was really faulty.I socketed it too for easy maintenance:
HD63C09EP
With a good CPU fitted game obviously booted but showed jailbairs over backgorunds:
jailbairs
This a common problem on this Konami hardware which uses graphics custom ASICs in QFP package.Specifically Lethal Enforcers uses sprite and tilemap generators and these work always in pair.My issue was located on backgrounds so I went to inspect the pair marked 054156/054157 and found some lifted pins on the latter @S8:
054157_ASIC
I promptly reflowed them with my hot air rework station and goodbye jailbairs!Game 100% fixed.
jailbairs_fixed
 Posted by at 8:39 pm
May 242015
I use OSH Park quite a lot for various projects.
Recently I received the second version of my JAMMA Supergun back but thats not all.
Inside the packet was a little note
gameon
A nice little touch I thought so here is a shameless plug for OSH Park.
Arabian Magic repair log
 PCB Repair Logs, Repair Logs  Comments Off on Arabian Magic repair log
May 242015
Antoher board from the same batch of Sega System18 motherboards.
Ths is the time of a Taito F3 game (PCB version), Arabian Magic to be precise.Hardware is quite powerful as you can see from specifications:
  • CPU: Motorola MC68EC020;
  • Sound CPU: Motorola MC68000;
  • Sound chip: Ensoniq ES5505 and ES5510 (DSP);
  • Video resolution: 320×224;
  • Board composition: Board and F3 cartridge;
  • Hardware features: four scrolling layers, two sprite banks, Alpha blending
Board was in good condition :
Arabian_Magic_PCB_
It worked fine except for two stuck intupts (P1 and P2 2nd button) as you can see from I/O TEST mode:
stuck_inputs_
In this kind of hardware all I/O (and watchdog, too) are handled by a custom ASIC marked TCO640FIO (120 PIN QFP package) @IC71:
TCO640FIO
All the inputs from JAMMA connector are connected first to pull-up resistor arrays so I checked them and they were good.Lastly I lifted involved PINs from ASIC but inputs were always stuck.So, at this point, replacing the ASIC, taking it from a donor board, was my last resort.So, time to remove and replace it:
TCO640FIO_removed
and…success!All the inputs were restored and game fully enjoyable!
working_inputs_
 Posted by at 10:33 am
SEGA System 18 repair log
 PCB Repair Logs, Repair Logs  Comments Off on SEGA System 18 repair log
May 232015
Some days ago a friend of mine sent me some faulty boards to be repaired.Among them there was a couple of Sega System18 motherboards which, according to him, were working fine except for audio issues.You may think these kind of faults are easy to fix but instead most of times they requires accurate and long troubleshooting since audio circuitry is made of a digital and analog part (the latter has a lot of passive components like diodes, resistors, capacitors, OP-AMPs and so on)
So I started my analysis with these optimistic assumptions.
The first motherboard (which, actually,  belonged to a Laser Ghost boardset) came without CPU and ROM board :
System18_motherboard
so I used the ones from a my Shadow Dancer boardset.When I power it up I could hear sound but it was disorted and missing some PCM samples.First thing I replaced both TL084 OP-AMPs and this improved  a little the quality of sound but not still perfect and sample were always missing.These ones are played by the ‘RF5C68A’ PCM chip manifactured by Ricoh:
https://en.wikipedia.org/wiki/Ricoh_RF5c68
Connecting its analog outputs to an external amplifier I could hear all the missing samples but then they were lost somewhere since they didn’t come to the OP-AMP inputs.So, time to investigate deeper.With my ESR meter I started to check capacitors in the analog section and I found  some electrolytic ones (three 100uF 16V @C32-C36-C44  and one 220uF 16V @C35, all of same manifacturer) with very high ESR:
bad_ESR
Once replaced them sound was clear and all PCM samples present again.
Let’s pass to the second boardset which came complete with its Desert Breaker ROM board :
Desert_Breaker_PCB
In this case music + sound FXs were all present but very noisy.For first I checked the two TL084 OP-AMPs (actually two NEC uPC804C ) with my oscilloscope and all outputs were fine except for a couple  of both operational @IC92 and IC93 which showed clear disturbs (measured in AC) compared with respective good inputs:
TL084_IC92_input_output
Replacing them both with equivalent parts fixed all the sound issues.
 Posted by at 4:37 pm
