Major Title 2 PAL dump added
 PAL Updates  Comments Off on Major Title 2 PAL dump added
Aug 072015
Today I dumped one PAL from a Major Title 2 PCB (M92 hardware) which has been converted into Undercover Cops.PALs on CPU board (M92-A-B) are the same for all M92 games but the ones on ROM board are specific by game with some exceptions though.In particular this Major Title 2 ROM board (M92-B-F) has two PAL16L8.The one labeled ‘MT2_B-2L-‘ can be found also on Gunforce (and maybe others) under different label but same equations, the other one ‘M72-B-7H.D’ was undumped until now.Dump has been tested as working in a GAL16V8 targeting device.
 Posted by at 10:18 pm
Aug 052015
Some days ago Dragos sent us some pictures of his Konami hybrid sound modules reworking.As most of you already know, this customs are used in many Konami arcade games.Specifically the ‘054986A’ is used on Lethal Enforcers, G.I. Joe, Metamorphic Force, Run & Gun, Premiere Soccer, Bucky O’ Hare, Violent Storm, Monster Maulers, Martial Champion, Mystic Warriors, Gaiapolis and Wild West C.O.W. Boys of Moo Mesa while the ‘054544’ is present on X-men and Xexex.A common fault on these customs concerns the SMT electrolytic capacitors that after some time start to leak ‘eating’ traces of the module.What Dragos did was to literally ‘undress’ the modules by removing the black paint using this paint stripper (that you can find in your country under a different name) revealing in this way all the traces and connections on top and bottom layer.Needless to say that this is really useful for everyone who wants to troubleshoot the modules.But, here are the pictures for a better understanding.Let’s start with the ‘054544’:
054544_3
054544_4
054544_5
054544_1
A nice black repaint is what it takes after a recap…
Here is below the ‘054986A’ in all its glory:
054986A_0 054986A_2
Above, a close up of jumper wires needed to patch some broken connections
054986A_3
In the picture above you can see the ‘054986A’ top layer exposed.The small IC on the bottom left between the two 10uF 16V capacitors is a 78L05 voltage regulator (SOT-89 package) which powers the 4558 OP-AMP and  the AD1868 DAC on the underneath of the module
054986A_4
Now Konami hybrid sound modules have no more secrets!Thanks again to Dragos.
 Posted by at 10:54 pm
Logic Pro 2 PAL dumps added
 PAL Updates  Comments Off on Logic Pro 2 PAL dumps added
Aug 052015
Another contribution from Andreas.This time he sent in the PAL dumps from a Logic Pro 2 PCB (a puzzle game released dy Deniam in 1997).Dumps have been made from three unprotected devices (two PALCE22V10 and a GAL16V8), there was also another GAL16V8 but the chip is faulty.We mark them as untested for now.Thanks again to Andreas.
 Posted by at 8:57 pm
J. J. Squawkers PAL dumps added
 PAL Updates  Comments Off on J. J. Squawkers PAL dumps added
Aug 012015
Andreas, one of our most assiduous contributor, sent us PAL dumps from a J. J. Squawkers PCB, a cute platform game from Athena. Dumps have been all made from unprotected PAL16L8A devices (PCB has also a secured GAL16V8, not dumped ) and they are assumed working for now.
Thanks to Andreas.
 Posted by at 8:54 am
CPS1 PAL update
 PAL Updates  Comments Off on CPS1 PAL update
Jul 302015
A CPS1 PAL update today but no properly a dump.This one is needed to run Daimakaimura on a ‘90629B-3’ B-BOARD so a different one compared to the original.I took only care of compiling the .JED, equations have been created by ‘aje_fr’ so all credits must go to him.You can read original thread here:
https://www.gamoover.net/Forums/index.php?topic=27862.0
The GAL16V8 programmed with this .JED must be installed in socket @1A, the other PAL needed is the one marked ‘IOB1’ @11D.Thanks again to ‘aje_fr’.
 Posted by at 9:56 pm
