Devil World repair log
 PCB Repair Logs, Repair Logs  Comments Off on Devil World repair log
Jul 212016
Got this Devil World PCB as non working. This game is running on a Konami Twin 16 hardware. It is a two layer board with the first one devoted to CPU/sound and the second one to GFX/video. The two faulty/replaced chips were on the video board and are highlighted in red.
devilworld1
Luckily the board was booting and got stuck on the RAM/ROM test screen with ROM #18 reported as bad (chip #1 on the board picture above).
devilworld2
That ROM is part of a 4 ROMs row which contains the GFXs. They are 40 pins Konami chips and looking in MAME I could see that they were 512kb MASK ROMs. I tried dumping it with my programmer but was unable as it found one dead pin. Compatible EPROMs for these are 27C400 so I burned one and replaced it.
The game was now booting but with a color problem on some tiles.
devilworld3 devilworld5
After a deep look at the video board I could find a Fujitsu 74LS153 located at 10H (chip #2 on the board picture above) with floating outputs (while inputs had healthy pulsing signals). I piggybacked it and got everything corrected. I desoldered the faulty one, put a socket and replaced it. Board is now working perfectly.
devilworld4 devilworld6
Joe & Mac Returns PAL dumps added
 PAL Updates  Comments Off on Joe & Mac Returns PAL dumps added
Jul 212016
Today I dumped the three PLDs from an original Joe & Mac Returns PCB.Devices were unsecured 18CV8 (two of them configured as registered and one as GAL16V8) so I read them in a standard programmer and then reversed equations into GAL devices.Keep in mind that two dumps require to be burned onto a GAL18V10 and one onto GAL16V8.
 Posted by at 9:33 am
Out Zone repair log #3
 PCB Repair Logs  Comments Off on Out Zone repair log #3
Jul 182016
Received this Out Zone PCB for a repair:
DSCN3862
Actually board was a factory conversion from a Zero Wing board (hardware revision ‘TP-015’).When I powered it up, I got nothing of screen, neither the  black and white wavy lines sign of the system being initialized like it happens in this Toaplan hardware :
Probing the 68000 main CPU releaved it properly received /RESET signal as well as clock was present.As usual I did my check on CPU/RAM/ROM data/address bus and all was fine.But I went to check the clock signal of the Z80 it was stuck high:
Z80_clock_probing
The clock is generated by a 28MHz oscillator then divided by a 74F163 and inverted by a 74LS04 before reaching pin 6 of Z80 with a frequency of 3.5 MHz:
sound_system
On this kind of Toaplan hardware the Z80 commands not only the sound system but also the I/O, this would explain why the whole system didn’t get initalized since the 68000 could not find the Z80 running.Confident I went to remove the 28MHz oscillator :
DSCN3871
Fitted a good one and :
DSCN3872
Board risen from its grave!Mission accomplished.
 Posted by at 1:05 pm
Jul 162016
Got this orginal Hellfire PCB (by Toaplan) for a repair:
DSCN3844
After some initial problem due dirty sockets of program ROMs and oxidized JAMMA edge connector which caused missing boots, I was greeted by this scenario:
Sprites were wrong, garbled and stretched all over the screen.This part of graphics is generated by the custom ASIC ‘FCU’ :
FCU_ASIC
I did a reflow of it but this didn’t lead to any improvement.Probing around I found a 6116 SRAM with some data lines stuck low:
DSCN3847
Chip failed once tested out-of-circuit:
6116@2W_failed
But still no big improvements.Testing TTLs with my logic comparator I found a 74ALS169 counter @3N with bad outputs:
DSCN3849
Its output pin 15 was almost shorted to VCC (only 7.9 Ohm measured)
DSCN3850
Once removed, the chip failed miserably :
74ALS169@3N_reworking
Finally the sprites were correctly drawn but blocky :
DSCN3853
I noticed that, if I pressed down the ROM 9 @4E, sprites were 100% restored:
DSCN3856
Removing the EPROM revealed oxidation on socket pins:
RSCN3858
So I replaced it:
DSCN3860
Installing a new socket fixed game completely.
 Posted by at 6:28 pm
Jul 122016
Had this original Double Dragon II – The Revenge in my faulty boards pile so I deciced to take a look it hoping to fix it and complete the trilogy in my collection:
DSCN3795
Once powered it up I was greeted by this static garbage screen:DSCN3797
A static screen is a clear sign of some trouble in the main code execution.So, for first, I went to dump the program ROMs and found a bad device which game me different checksum at each reading.Since my ROM set was an undumped japanese one, I was forced to convert my board into the US set which is available.This did not lead to any improvement so further investigation was needed.When I removed the EPROMs, I noticed that the socket @IC63 (the one of the bad EPROM) was oxidized:
DSCN3798
I decided to replace it.When , before installing the new one, I was checking all the connections, I found an eaten trace underneath which should have tied pin 2 of the 74LS138 @IC64 (which generates the /CE signals for program ROMs) to pin 9 of a 74LS273 @IC71:
broken_trace_IC63_
Once restored the connection board finally booted up but with severe sprites issues and corrupted/missing sound FXs:
Probing RAMs on video board I found some data lines stuck low on a TMM2015 @IC83 :
DSCN3816
This was due two broken traces on solderside which I promptly patched:
broken_trace_IC83
This improved a little the issue giving back the missing lines to sprites but they were still wrong and garbled.Looking at MAME source, I could figured out that one of the two Z80 (the one @IC50) on top board is used as sprites CPU which takes data from a 27512 EPROM @IC37 and write/read them on a 6116 SRAM @IC24 :
srpites_CPU_circuitry
Probing this static RAM (actually a Sanyo LC3517BSL compatible with 6116) revealed weak signals on its address bus:
DSCN3819
Once removed the chip, it failed when tested out-of-circuit:
TMM2015@IC24_reworking
With a good RAM chip all the sprites were correctly restored :
sprites_restored
So I moved to troubleshoot the sound FXs issue.Samples are played by an OKI MSM6295 @IC74 with takes data from two 28 pin 1Mbit MASK ROMs @IC39 and IC40:
ADPCM_circuitry
Probing the two MASK ROMs revealed that data came out when requested so the problem had to be in the OKI MSM6295 chip which played them badly.I removed it :
DSCN3831
and put back a good one:
RSCN3833 This restored ADPCM samples.Board 100% fixed and board trilogy complete!
 Posted by at 7:21 pm  Tagged with:
