Decrypted FD1089 ROMs
 General  Comments Off on Decrypted FD1089 ROMs
Aug 192014
Runik is back and now he can decrypt FD1089 games.
The first two have been added (both Aurail sets).
As usual if anyone can test these files please let us know.
Any requests also please let us know.
Big thanks to Runik for making all of these. He has put a lot of work into making these for other people.
 Posted by at 5:17 pm
Dumping a NES cartridge
 General  Comments Off on Dumping a NES cartridge
Aug 112014
Recently I offered to help out someone wanting his Super Adventure Quests NES cartridge dumped.
I was quite surprised at first as I thought all NES carts had already been dumped but apparently not.
Here is the cartridge in question.
IMAG0749
IMAG0748
This is the same as the already dumped cartridge of Quattro Adventures. This was the NTSC release where as Super Adventure Quests was the PAL release.
The whole reason this dump in particular was wanted is because the NTSC release doesn’t work on a real PAL console using the Everdrive cartridge.
I got hold of this cart and decided the best and quickest way of dumping it was to desolder the ROM chip and read it out.
IMAG0754
I looked online and the very small amount of information I could find suggested it was most likely a 23C2001 MASKROM pinout. As my programmer has support for this device it should have been good to go.
Well it didn’t work so after mapping out the connections on the PCB it looks like the pinout is the same as a 27C020.
This worked just fine.
Copying the iNES header from Quattro Adventures and prepending it onto my ROM allowed me to load it up in emulators to check it.
nestopia
Job done. This has now been added to MESS.
Jul 202014
At the moment I have an X Multiply PCB that shows a “RAM NG 10” error on startup.
Although I have yet to find the problem with this board I thought it best to find out exactly what RAMs these errors are referring to.
To make any sense of this you will need the memory map for the game found in M72.C file of the MAME source code.
Here is a short list of what I have found so far:
0x9c000-0x9ffff = RAM NG 1 (Work RAM)
0xc0000-0xc03ff = RAM NG 10 (Sprite RAM)
0xc8000-0xc8bff = RAM NG 9 (Palette RAM 1)
0xcc000-0xccbff = RAM NG 8 (Palette RAM 2)
0xd0000-0xd3fff = RAM NG (Video RAM 1)
0xd8000-0xdbfff = RAM NG (Video RAM 2)
 Posted by at 8:30 pm
Cheap and easy -5v
 General  Comments Off on Cheap and easy -5v
Jul 152014
Its becoming more and more common for power supplies to not supply -5v.
There are devices out there like the “Negatron” that offer a nice and easy way to obtain an adjustable -5v but there is a much cheaper way of getting it providing you can do a little bit of soldering.
Intersil offer a 7660 voltage converter IC. Its an 8 pin DIP device that can be bought for under £1 from Farnell and other places.
Farnell – ICL7660
I bought a couple of these on a recent order to test and the results, as expected, are great.
This is it setup on breadboard.
IMAG0673
IMAG0674
All that’s required is a +5v input, the ICL7660 IC and 2 x 10uF capacitors to get a -5v output. Add a variable resistor into the mix and you have a fully adjustable device for very cheap.
Here is the diagram lifted straight from the datasheet to show how simple this is.
icl7660
 Posted by at 9:16 pm
