Oct 052014
Been doing a few bits with muddymusic’s Jumping PCB.
I wanted to see how the C-Chip substitute ROM was wired into the circuit so ive made a small schematic and reversed the address decoder PAL.
Jumping Schematics
click the pic for full size.
Here are the equations for the address decoder too. Ive renamed to the pins to something more suitable for human consumption.
/* Inputs */
Pin 1 = A23;
Pin 2 = A22;
Pin 3 = A21;
Pin 4 = A20;
Pin 5 = A19;
Pin 6 = A18;
Pin 7 = A17;
Pin 8 = A16;
Pin 9 = A15;
Pin 10 = A14;
Pin 11 = A13;
Pin 13 = FC0;
Pin 14 = FC1;
Pin 23 = FC2;
/* Outputs */
Pin 15 = CA12; /* A12 of C-Chip replacement ROM */
Pin 16 = CA13; /* A13 of C-Chip replacement ROM */
Pin 17 = CA14; /* A14 of C-Chip replacement ROM */
Pin 18 = CA15; /* A15 of C-Chip replacement ROM */
Pin 19 = LROM; /* Chip enable for other ROM’s */
Pin 20 = A; /* Pin 1 of 74LS138. Input A */
Pin 21 = B; /* Pin 2 of 74LS138. Input B */
Pin 22 = C; /* Pin 3 of 74LS138. Input C */
/* Equations */
!CA12 = !A23 & !A22 & !A21 & !A20 & !A19 & !A13 #
!A23 & !A22 & !A21 & A20 & !A19 & !A18 & !A17 & !A16 & A15 & A14 & !A13 #
!A23 & A22 & !A21 & !A20 & !A19 & !A18 & !A17 #
!A23 & A22 & !A21 & !A20 & !A19 & !A18 & A17 & A16 #
A23 & A22 & !A21 & !A20 & !A19 & !A18 & !A17 & !A16 & !A13 #
!A23 & !A22 & !A21 & !A20 & A19 & !A18 & !A17 & !A13 #
A23 & A22 & !A21 & A20 & !A19 & !A18 & !A17 & !A16 & !A15 & !A14 & !A13;
!CA13 = !A23 & !A22 & !A21 & !A20 & !A19 & !A14 #
!A23 & A22 & !A21 & !A20 & !A19 & !A18 & A17 #
A23 & A22 & !A21 & !A20 & !A19 & !A18 & !A17 & !A16 & !A14 #
!A23 & !A22 & !A21 & !A20 & A19 & !A18 & !A17 & !A14;
!CA14 = !A23 & !A22 & !A21 & !A20 & !A19 & !A15 #
A23 & A22 & !A21 & !A20 & !A19 & !A18 & !A17 & !A16 & !A15 #
!A23 & !A22 & !A21 & !A20 & A19 & !A18 & !A17 & !A15;
!CA15 = !A23 & !A22 & !A21 & !A20 & !A16;
!LROM = !A23 & !A22 & !A21 & !A20 & !A17;
!A = !A23 & !A22 & !A21 & !A20 & !A19 & !A18 #
!A23 & !A22 & !A21 & A20 & !A19 & !A18 & !A17 & !A16 & A15 & A14 #
!A23 & !A22 & A21 & !A20 & !A19 & !A18 & !A17 & !A16 & !A15 & !A14 & !A13 #
A23 & A22 & !A21 & !A20 & !A19 & !A18 & !A17 & !A16 #
!B = !A23 & !A22 & !A21 & !A20 & !A19 #
!A23 & A22 & !A21 & !A20 & !A19 & A18 & !A17 & !A16 #
!C = !A23 & !A22 & !A21 & !A20 & !A19 #
!A23 & !A22 & !A21 & !A20 & A19 & !A18 & !A17;
The A, B and C outputs from the PAL feed into a 74LS138. In order to select the C-Chip substitute A and B must be HIGH and C must be LOW. From the equations (or just looking at the MAME source code) we can work out that the C-Chip ROM lies at address 0x80000.
So, not a great deal of info but its pretty interesting all the same.
Atomiswave -> NAOMI: Metal Slug 6
 General  Comments Off on Atomiswave -> NAOMI: Metal Slug 6
Sep 202014
Its a little known fact that I’m a big Metal Slug fan. Its little known because ive only recently got into playing it on a friends Neo Geo CD system.
It came as a great surprise when Darksoft announced that Metal Slug 6 has been converted to the NAOMI as I had never played it before and had also seen nothing of it.
Im happy to say it works perfectly and have had a fun morning shooting aliens.
Thanks to Darksoft for continuing with this project and for once again introducing me to more hidden gems from a system I’m likely never to own again.
IMAG0900
IMAG0901
IMAG0902
 Posted by at 2:04 pm
PLD Archive update
 General  Comments Off on PLD Archive update
Sep 132014
Just a quick note.
The PLD Archive has now been split into two, A-M & N-Z.
This needed to be done as the table was becoming slow and unresponsive for us when we are updating it and we were fearful of a database crash.
Nothing else has changed and all the entries should still be present but you will need to select the table you want to see from the page.
Thanks
 Posted by at 12:37 pm
Spectral vs Generation sheet
 General  Comments Off on Spectral vs Generation sheet
Aug 202014
I was recently asked if I could scan in the manual (its not much of a manual, just a bit of paper) from my SvG.
Anyway here it is for anyone thats interested.
DOWNLOAD HERE
svgthumb
 Posted by at 4:26 pm
