Dec 312014
today I got a couple of Oric computers.
Ive been after one of these for some time now but prices have shot up of the last 12 months.
I couldn’t resist buying these two, both of them which required repair, as the price was right.
IMAG1141
First is red/black one.
I first started by removing the ULA and powering up to check voltages. I do this with Spectrum’s too as these early voltage regulators have a habit of going wrong with disastrous consequences.
With everything looking OK I refitted the ULA and power up. I was greeted with this screen.
IMAG1145
Ive read enough about the Oric over the years to know that the ULA is very hardy and the RAM is very poor. Ive also read that a fried ULA will usually result in nothing on screen at all.
I opted to desolder the RAM first.
There are 8 x 4164 RAM chips and on testing two of them failed.
I socketed and replaced the faulty RAM and I now have this
IMAG1147
The random writing is my doing as the keyboard is flat on the bench when testing.
Happy with this. I think the second unit has the same fault too.
SEGA Mega-Tech PALs added
 PAL Updates  Comments Off on SEGA Mega-Tech PALs added
Dec 302014
Zebow2002 has loaned me a Mega-Tech motherboard and a bunch of games. Here are dumps of the 3 PAL’s found on the board.
At this point they are untested but I could really do with them being tried out as they may be the cause of the fault.
Thanks to Zebow2002
 Posted by at 12:22 pm
Fluke 68000 POD repair log
 Equipment Repair Logs, Repair Logs  Comments Off on Fluke 68000 POD repair log
Dec 292014
Whilst doing some testing for Guddler over on the UK-VAC forum I thought it would be a good time to look into why I sometimes get a POD timeout error.
Normally when I get this error pushing down on the black cable that connects it to the 9010 fixes it.
Here is the reason why
IMAG1127
One of the crimps had worked its way loose.
I carefully bent the small bard out a little and refitted. Now the POD seems to be rock solid.
Hard Drivin GAL dumps added
 PAL Updates  Comments Off on Hard Drivin GAL dumps added
Dec 292014
muddymusic dumped the Hard Drvin GAL16V8’s from his board set. They were unlocked so are assumed working but have not been tested.
Thanks to muddymusic
 Posted by at 3:03 pm
Super Pang PAL redump added and verified
 PAL Updates  Comments Off on Super Pang PAL redump added and verified
Dec 282014
Today I dumped the only PAL from an original Super Pang PCB.Equations are the same of the ‘CW-P’  dump already in the database but device (a PAL16L8) is marked ‘POKER’ on mine board like the PAL from Pang dumped by me some time ago.Equations are the same of the Block Block PAL as well.Dump is tested as working in a GAL16V8 replacement.
 Posted by at 10:44 pm
