Some days ago I had on the bench this Wolf Fang: Kuhga 2001 PCB (known outside Japan as “Rohga – Armor Force”) , a good-looking horizontally scrolling shoot ’em up manufactured by Data East in the 2001 :
When I powered it up, I was greeted by this screen.
It was a clear lack on SYNC signal confirmed also by a measurement with a frequency counter on pin 13 solderside of the JAMMA connector.So, given the absence of schematics, I started to trace back the signal with a multimeter but couldn’t find where it was generated.Visually inspecting the board I found a suspicious crack over a trace :
My multimeter confirmed the trace was really severed.After patching it, the SYNC signal was restored but there were jailbairs on the sprites:
Sprites are stored in some 42 pin MASK ROMs :
I visually inspected the area and found another broken trace on solderside which lead to a data line of these MASK ROMs:
I promptly patched it with some AWG30 wire:
and sprites were restored:
But after this I realized that sound was missing at all.Diverting the audio signal to an external amplifier, I could hear both music and sounf FXs but there was no output from the TA8205AH amplifier on PCB :
So I decided to remove and replace it but , as for my previous Pitfall II repair, I was wrong, it was good.Looking at its datasheet, I could figured out how its mute circuit was made:
Checking the 220uF 16V electrolytic capacitor connected to pin 8 of the amplifier gave me a dead short across the terminals.So I desoldered and test it out of circuit having confirm it was really shorted:
Replacing it restored full sound.End of job.
6 Responses to “Wolf Fang: Kuhga 2001 repair log”
Hey, just bumped into your blog and have been reading it from page 1 until now. Very well done and well documented repairs. I have dabbled in board repairs and have a few logs out there, but no where near the amount that you have.
Congrats, and please keep up the good work!
Thank you.And more logs are coming!
I forgot.Could we add your blog to our links section?Thanks.
Absolutely.
http://www.jrtwine.com/blog/?tag=arcade
The tag will help hide the other cruft on the blog site.
Added, thanks.
Excellent work as always
Best Regards
JOSÉ GONÇALVES
