Jun 042018
Was asked by a friend to repair his Sunset Riders.
When starting up the PCB, it was stuck in something resembling a watchdog fault.
But I’ve been working on Sunset Riders before and this didn’t seem like an ordinary watchdog. I felt that it went a little bit longer in the startup sequence before crashing.
The board was a bit dirty but I started with the usual:
- Checking CPU signals like clock, reset and halt
- Verifying the program ROMs
- Checking the program RAM for odd signals
All looked ok, but then I found this at the 051550 reset signal generator.
Pin 1 on the 051550 looked like a cold solder joint.
Pin 1 is the clock signal input pin on this IC and without that input, I can understand that the game doesn’t boot up properly. Gave that pin a dab of solder
And booted up the game
Board fixed without any other issues 🙂
