Nov 152014
First of all I want to thank JROK for providing me all the technical info and allowing its public release, without his help I would not have ever made.Let’s start with the story.
Some time ago a  friend of mine sent me his Splatterhouse PCB bought as working saying it got stuck upon boot  on ‘ROM TEST START!! PLEASE WAIT..’ message displayed upside down on a screen filled with red zero.So I started to investigate on the net and found that usually this kind of issues are caused by a faulty custom chip marked ’64A1′ @M4 on ROM board.This was confirmed by swapping this IC in another CPU board of Galaga88 with this missing component , in this case I got an ‘EEPROM ERROR’ message which is a further proof of the fault.
Thanks always to JROK we know that this ’64A1′ custom IC is nothing else than a HD63701 MCU with the exception of two custom opcodes not present in original part.You can go deeper into technical reading here:
https://www.jrok.com/hardware/cus60/cus60_an_owners_guide.html
In the specific you have to change three bytes in the ROM  “VOICE0” at a specific offset.For example :  in Splatterhouse the offset is $FA8B and the new HEX values are “20 01 56”.
The string to search for in HEX is  “B7 C0 00 6E 00” and the first 3 bytes must be changed to  “20 01 56”
The patch seems to be needed at offset $FA8B for most games, but not all. Here’s a reference table :
Tank Force – $FA29
Blazer – $FA8B
Dragon Spirit – $FA8B
Galaga 88 – $FA8B
Marchen Maze – $FA8B
Splatterhouse -$ FA8B
Rompers – $FA8B
Blast Off – $FA8B
World Court – $FA8B
Beraboh Man – $FA4E
Dangerous Seed – $FA8B
Face Off – $FA29
Puzzle Club – no voice ROM !
Quester – $FA1B
HD63701VOC
So, it was only matter to program one of these MCU with MAME dump using my Hi-Lo Systems ALL-11C EPROM programmer and, at the same time, replace the ROM ‘VOICE0’ with the properly patched one.Once done, I had confirmation of what the good JROK said about. Operation  ‘NAMCO custom 64A1 replacement’ accomplished.
 Posted by at 7:14 pm
  2 Responses to “Splatterhouse repair log #2”
  1. Hi Caius
    Where did you manage to find a supply of HD63701VOC?? I’ve been looking for one of those for a long time and have never been able to find one, let alone 9!!! Would you be prepared to sell me one?
  2. Hi cmonkey, I’ve ben lucky since I put a request on CPU-WORLD forums:
    http://www.cpu-world.com/forum/viewtopic.php?t=24218&highlight=hd63701
    and somebody contacted me selling 10 HD63701V0C (one was used for this Splatterhouse).
    But, write me in private so I can give you more details.
