Aug 072016
Today we have a big Irem PLD update.
The user ‘frsj8112′ sent in dumps from Hammerin’ Harry (M84 hardware) and Pound for Pound (M85 hardware).The two from Hammerin’ Harry are specific to this game and located on M84-C-B board (the middle one) while The Pound for Pound ones are two on CPU board (the middle one) and one on video board (the top one with scratched off customs).All dumps have been successfully tested on GAL16V8 targeting devices.
Besides, he tested on his Hammerin’ Harry PCB the PALs from our archive ‘m84.zip’ we got from unknown source and found that the one named ‘m84-c-3a_ic8.jed’ is the correct one for this board and it’s unique to this game while  the one name ‘m84-a-2h_ic5.jed’ is the same over all the different M84 games.The ones @5L and 7D should be different from game to game.
He also reported feedback on BPROMs.According his tests the bipolar PROM @C37 on M82-B-A VIDEO board can be found also on M84 and M85 hardware although at different location and with different labels.Here’s a reference table fo this BPROM:
  • M72: IC66  (to be verified)
  • M81: IC72  (verified)
  • M82: IC37  (verified)
  • M84: IC21  (verified)
  • M85: IC5   (verified)
Thanks again to ‘frsj8112’ for his work.
 Posted by at 11:18 am
Aug 062016
After Lifeforce, another awesome Konami shoot ’em up on the bench, it’s the turn of Gradius II – GOFER no Yabou :
DSCN3879
DSCN3880
Both CPU and video board were in great shape but this is what I got once powered it up:
DSCN3876
Board sat down on the above message and very rarely showed an ‘ADDRESS ERROR’ or ‘ILLEGAL INSTRUCTION’ message:
DSCN3875
Thanks to my friend Josef who sent me a good Gradius II boardset I could narrow the fault in the CPU board but, before knowing this, during my troubleshooting I found with my logic comparator a couple of faulty Fujitsu TTLs, a 74LS32 @7W on video board and a 74LS157 @8G on CPU board  :
74LS32@7W_reworking
74LS157@8G_reworking
TTL_testing
So I could concentrate exclusively on CPU board since I know the fault was there for sure.Probing the board with my oscilloscope I found some abnormal activity on a couple of 6264 RAM @10E and 10G :
10G_10E_data_bus
Launching the game on MAME I could figure out that these two RAMs are used by both the main and slave 68000 CPU :
selftest
So a failure in them would explain the missing boot.Not being able to determine which chip was actually faulty, I desoldered both and added sockets:
10G_10E_socketed
The one @10G didn’t pass the out-of-circuit test failing in address 1073:
6264@10G_failed
Finally the board could properly boot and enter in game but with missing graphics and crashing after few seconds all the time :
Probing around again with my logic comparator I found a 74LS74 @6F with bad outputs, once removed it failed :
74LS74@6F_removed
74LS74@6F_failed
This fixed the board completely, no other issue were present.Evil Konami defeated again.The battle goes on.
100_8491
 Posted by at 10:36 pm
Lifeforce repair log
 PCB Repair Logs  Comments Off on Lifeforce repair log
Aug 062016
Received this Lifeforce PCB for a repair:
DSCN4031
Board suffered from a backgrounds issue, screen was filled of blocks of garbage instead of correct tiles.Here a comparison with MAME snapshots.This in the title screen:
title_comparison
This is the in-game :
ingame_comparison
A video for a better understanding:
The hardware uses the famous ‘GX400’ video board :
DSCN4032
The peculiarity of this board is the lack of ROMs, all the graphics is generated by logic of TTLs and custom ASICs.Anyway I has a good starting point since the owner assured me the customs were all good so the problem was TTL related.So I started to check for abnormalities with my logic probe.All was good until I found some 74LS157 with stuck inputs.According schematics they come from a 74LS273 @12B:
74SL273@12B
As you can see this TTL latches data bits from a 6464 SRAM  @15B which is addressed by the custom ‘0005291’ @20D (probably a tilemap generator).Probing it with a logic analyzer confirmed the outputs were all stuck low or high (only one gate was analyzed but all other were confirmed stuck as well with my oscilloscope) :
74SL273@12B_logic_analysing
So confident I removed it (I forgot, obviously it was from Fujitsu):
DSCN4033
Once tested out-of-circuit, it failed miserably:
74SL273@12B_failed
Fitted a rounded  machine-tooled socket and a good chip:
74LS273@12B_new_fitted
And:
fixed
Once again Evil Konami has been defeated!See you in the next chapter of this neverending battle…
 Posted by at 11:00 am
Out Zone repair log #4
 PCB Repair Logs  Comments Off on Out Zone repair log #4
Aug 032016
Another Out Zone PCB (this time on usual ‘TP-018’ hardware) on the bench:
DSCN3960
Board was in good shape but I noticed it was heavily reworked on solderside, a lot of ICs were replaced and PCB was not cleaned from solder flux residuals:
DSCN4039
Besides, some ground pins of JAMMA edge connector were partially missing or burnt (sign that something gone shorted) and a 100 nF mylar capacitor was missing.I promply restored all of them:
DSCN4022
Board booted into game but some sprites were wrong (more than a palette problem it seemed to me an issue related to data bus as if sprites were missing some layers) :
sprite_issue
When I went to read the four 1Mbit ROMs containing relevant data I noticed devices were put in wrong sockets:
DSCN3961
Silkscreening under the sockets clearly tells where these MASK ROMs must be placed:
DSCN3962
But also with ROMs in correct position some sprites were still wrong.I started to test the part of circuit involved in sprites generation and all was fine until I came across two data lines shorted on a 6264 RAM @10A :
DSCN4006
The two data lines are connected to the sprites generator custom ‘FCU-2’ and to inputs of a couple of 74LS374 so the short was present also on them.Lifting a pin of the custom didn’t clear the short.
DSCN4044
Obviously due the not high resolution of a simple multimeter I could read always a dead short on each of this component.So I decided to use my Polar Toneohm 850A short locator (essentially an audible milliohmmeter) in order to locate the minimum resistance point.
1,110 Ohm measured on the two shorted data lines (pin 12 and 13) of the 6264 RAM @10A:
DSCN4007
Around 700 mOhm measured on the two pins of the custom ASIC ‘FCU-2’:
DSCN4009
19.3 mOhm on the 74LS374 @19E
DSCN4012
17.2 mOhms on the 74SL374 @19C and beep was squeeling at higher frequency :
DSCN4011
So I was approaching to the short, it was in the area of the two 74LS374.On part side I didn’t notice anything abnormal so I went to inspect the solder side and after some time I find the culprit:
pin13-pin14_74LS374@19C_bridge
Two pads connected to  inputs of the two 74LS374 were bridged, a ‘kind’ gift of previous repairer.I warmed up my soldering iron and removed it.Powered up the board again :
fixed
Board 100% fixed.Mission accomplished.
 Posted by at 11:27 pm
Snow Bros repair log #2
 PCB Repair Logs  Comments Off on Snow Bros repair log #2
Aug 012016
A quick fix for a PCB that seems to develop always same issue judging from my experience and other repair logs.Received this Snow Bros for a repair:
DSCN3977
It was playing fine but some sprites suffered from flickering (it’s hard for my camera to capture this, see from second 5 of below video)  :
Maybe you can understand better from this picture provided me by the PCB owner:
snowbros02
The sprites are generated by the Pandora custom chip which read data from a MASK ROM and write them to four 4464 (64K x 4bits DRAMs) :
sprites_circuitry
When I went to probe these dynamic RAMs with my scope all was good except one data line (D2, pin 3) of the one @IC24, signal was weak and stuck high compared to an healty one:
data_line_4464_IC24_comparison
Confident I removed the chip which failed when tested out-of-circuit:
41464@IC24_failed
Installed a socket for a fresh chip:
DSCN3980
and tested again the board:
DSCN3981
No more sprites flickering and game 100% fixed.
 Posted by at 10:19 pm
