Avenging Spirit Repair log
 PCB Repair Logs, Repair Logs  Comments Off on Avenging Spirit Repair log
Oct 312016
Received this game for a repair.
The game had messed background images
avenging2
Shorting some data pins rams I found the one responsible for the tiles arrangement.
I replaced the one marked in red below and it was infact faulty but it didn’t fix completely the problem.
I noticed that the 74ls745 above it was pressed down badly like if it was hit but something.
I decided to unsolder it and test the continuity of all the pads and infact I found three of them (marked in red) that visually were OK but they had no continuity
with the other chips.
That meant that the internal pad was broken so bad it detached internally
avenging1
Making some ugly flying wiring with something I had at hand I tested the game which was fully restored
avenging4
avenging3
Double Dragon repair log #9
 PCB Repair Logs  Comments Off on Double Dragon repair log #9
Oct 292016
Yes, yet another Double Dragon PCB on the bench.
The board was in good shape:
100_8956
but it didn’t pass the self-test sitting on a ‘63701 ERROR:
100_8959
The /HALT line of the HD63701 MCU was asserted, this was sign of some trouble in its busses.I swapped a good chip with no change so I went to look at schematics.All was good until I found no continuity between the address line ‘A0’ (pin 50) of the MCU with pin 3 of the 74F157 @IC8:
hd63701_bus
Tracing back the address line I could figure out where connection was  interrupted, exactly under the 74F157 @IC7 so I removed it.Inspecting the involved area with a USB microscope revealed a corroded trace  :
bad_trace
I patched it with some AWG30 wire:
100_8979
With this fix finally the board passed the self-test but two issues were present in game : sound was missing and backgrounds had jailbars :
The first issue was due a missing 10Kohm potentiometer in the sound section:
100_8981
The backgrounds GFX data are stored into four 27512 OTP devices on video board :
bg_romsjpg
When I went to dump the ones @IC108 ans IC109 my programmer warned me about a bad contact on pin 19 (data line ‘D7’) of both :
27512ic109
Obviously the resulting dumps didn’t match the ones from MAME ROM sets so I programmed two 27C512 EPROMs as replacement.This restored graphics completely.Yes, yet another Double Dragon PCB fixed!
 Posted by at 11:46 pm
Van-Van Car PAL dump added
 PAL Updates  Comments Off on Van-Van Car PAL dump added
Oct 292016
I dumped a PLD  from a working Van-Van Car PCB (manufactured by Sanritsu or Karateco).Device was a unprotected PAL16L2 labeled ‘VAN-83’ @IC79, there are other three PALs on PCB but they are registered and secured.Dump is tested as working in a GAL16V8 targeting device.
 Posted by at 6:18 pm
Sky Wolf PAL dumps added
 PAL Updates  Comments Off on Sky Wolf PAL dumps added
Oct 232016
Today I dumped the PALs (three secured PAL16L8) from a Sky Wolf PCB (bootleg of Airwolf).Devices are located on CPU board.Dumps have been successfully tested on GAL16V8 targeting devices.
 Posted by at 4:37 pm
Kaneko Super Nova ROM board PAL dumps added
 PAL Updates  Comments Off on Kaneko Super Nova ROM board PAL dumps added
Oct 232016
Found two ATF16V8 PLD’s in a Super Nova ROM cartridge. Both were unlocked but have not been verified as my PCB has a fault. The equations look good.
The ROM board is marked ROM-2.
 Posted by at 4:00 pm
