Snow Bros (bootleg) repair log
 PCB Repair Logs  Comments Off on Snow Bros (bootleg) repair log
Dec 242016
We all know that a bootleg is a copy of an original board and often a not perfect one since they could be not well engineered.They can suffers from different issues, the one that occurs most often is an unstable video SYNC.Just like this Snow Brows bootleg:
Board played fine but screen was wavy :
Analyzing the SYNC signal with a scope,  amplitude of pulses seemed a little bit over the standard , +4.16V as average while usually they should be within +4V :
This was most likely the reason why my monitor didn’t like it so I thought about a workaround.Usually it’s suggested to use a 5K Ohm potentiometer set as voltage divider : one terminal to the SYNC signal generated by the PCB, the other tied to GROUND and the wiper (the central one) to the  SYNC pin of JAMMA connector.In this way you can adjust the SYNC signal voltage between the original voltage level and GROUND.I wired the potentiometer in this way and installed it on the JAMMA connector of my supergun.Adjusting it, I got a stable screen but I wanted a permanent solution on the PCB.So I used two resistors as a voltage divider:
In my case I used a 270 Ohm resistor as R1 and a 4.7K Ohm as R2 since, doing a bit of calculation, this should have been enough to bring the signal within standard : 3.93V=4.16V*4700/(270+4700).
I installed the voltagev divider on the solderside of PCB (obviously I first cut the trace going to PIN 13) .
This was what I measured:
My monitor was finally happy with it.End of job.
 Posted by at 3:53 pm
Daimakaimura (B-BOARD ‘88622B-2’) PAL dump added
 PAL Updates  Comments Off on Daimakaimura (B-BOARD ‘88622B-2’) PAL dump added
Dec 212016
Today we have the PAL dump from a Daimakaimura (Japanese version of Ghouls ‘n Ghosts on a CPS1 B-BOARD ‘88622B-2’ ) thanks to Silvio Grazini who sent the binary dump obtained with the Charles MacDonald 27C020 PAL adapter.I took care of reversing equations onto a GAL16V8 and Silvio successfully tested it on his board.Thanks again to him.
 Posted by at 7:38 pm
Karate Champ repair log
 PCB Repair Logs, Repair Logs  Comments Off on Karate Champ repair log
Dec 192016
I bought this game for my collection.
I had already Karate Champ player vs player but this one was the rarer first version , japanese revision titled Karate Dou.
The game was very dirty and rusty and despite being declared fully working, the sound was completely missing.
The seller proposed a refund by sending back the pcb.
Before taking this road I decided to give a try at repairing it since the schematics for this pcb are available on jammarcade.net (they are not the same as the more common player vs player!) and the hardware was pretty simple.
After cleaning it in the washer machine, I started the trouble shooting
I immediately noticed that all the 7 sound eproms (BE2o – BE26) and the ram beside them had no activity on the data lines.
So I probed the /CE line and it was stuck high for everything.
That means the devices are in standby mode and they cannot output anything.
With the help of the schematics I traced back the source of the problem to IC18, a 74ls138 who outputs were all stuck high despite the activity on the inputs.
After replacing it, I tested out of circuit and the programmer confirmed it was faulty
By replacing IC18 with a good one, the sound was fully restored.
Note: If you have Karate Champ player vs player which use the same adapter, only remember that the older Karate Champ uses also -5V for the pre amps. If you forget to wire it , you get a very noisy and hissing sound.
Terra Cresta repair log #2
 PCB Repair Logs, Repair Logs  Comments Off on Terra Cresta repair log #2
Dec 192016
I got this faulty pcb in change of some repairs.
The seller told me that the game was bought as working but after some time it developed a problem on the background with some repeated tiles all over the place.
I could confirm the behaviour, but after a couple of troubleshooting sessions the problem became worse and the background was only white.
The game has not schematics, so after some time spent to understand where the background generator was sitting I could isolate the problem on the ram@18D which had some data lines stuck low.
After replacing it, the problem remained but at least the ram had all the datalines working.
With the logic probe I then found a 74ls273@18E which had all the outputs in the grey area.
After replacing it, the background was fully restored
Dec 182016
This c64 gave me the following screen on power-up. Flickering characters with artifacts and a vertical line through the middle of each character. After going through the symptoms on Ray Carlsen’s site, I thought this may be bad colour ram. Swapping out the 2114 didn’t make any difference and colours associated with the characters looked good anyway, so I don’t know what I was thinking there.
After thinking about this for awhile & looking at the pattern closely, I had an idea that this may be a bad character generator ROM at U5. To prove this theory, I could type in a short basic program to copy the entire character set from the ROM into RAM, then tell the VIC 2 chip to use the character set in ram and reprogram one of the characters to one of my choice. The Commodore 64 has great features such as programmable characters which is very useful for games.
Luckily I don’t have to think too much as there’s already an example at the link below.  So I begin typing some basic commands. The problem is my typing has to be super accurate because I can’t see what I’m doing and any typo will screw the troubleshooting up. It took me 3 or 4 goes before I finally got it right.
https://www.devili.iki.fi/Computers/Commodore/C64/Programmers_Reference/Chapter_3/page_109.html
After typing in “POKE 53272,(PEEK(53272)AND240)+1” as shown above, the flickering stopped although the artifacts obscuring the characters were still there, which was to be expected because we’ve just copied corrupt data. The computer was now getting the character set from RAM instead of from ROM. Now to change the letter T to a smilie face. I enter the following program and run it.
10 FOR I=12448 TO 12455: READ A:POKE I,A:NEXT
20 DATA 60, 66, 165, 129, 165, 153, 66, 60
Pressing a T shows a smilie face which looks complete without artifacts or a line through the middle of it. So I know that the VIC 2 chip is OK.
I remove the old mask rom and install a socket. My EPROM programmer is currently out of action so I don’t have the ability to verify the character rom or program another EPROM in its place.
But for now I can extract a known working EPROM from my own C64 into this one for troubleshooting purposes . After powering up, the character set shows up perfectly. Now all I have to do is program another EPROM when I get around to it and this c64 can go back to its owner.
