At first I thought it was a maskrom problem but once I checked all of them only to find they were good, I started to probe the ram responsible for the background.
A sram @IC31 had some weak data signals so I decided to change it and the guess was right because the game was fixed.
PCB Repair LogsComments Off on Michael Jackson’s MoonWalker repair log #1
May212017
Another board from the recent operator raid, an original Michael Jackson’s MoonWalker (on Sega System 18 hardware)
Despite its age and the use of the FD1094 CPU module with battery backed-up RAM the board was still working except for the sound samples (drums, speeches, etc..), they were missing or replaced by random ones:
The hardware uses a rebranded Ricoh RF5C68 as PCM sound chip :
Not able to find any datasheet I went to “listen” its pins with an audio probe.When I hit the analog outputs (the IC has an on-board DAC) I realized that sound came already wrong out of it.So the chip was the only responsible and it needed to be replaced:
Picked-up this Asterix PCB in a recent operatot raid:
Board was physically damaged, one part of PCB was litterally missing and the nearby 16Mbit MASK ROM was cracked in half:
The affected part was not a vital section of circuit (but only a spare room for not used additional MASK ROMs) so board still booted but sprites were missing.If I pressed the ‘053245’ ASIC they came back but garbled and blocky:
For first I reflowed some bent pins of the ‘053245’ sprites generator:
Then I replaced the broken 16Mbit MAS ROM @3K with a compatible 27C160 :
This improved things but not still perfect :
The MASK ROMs check complained about the other device containing sprites data (the one @7K)
Like said in my previous Parodius DA! repar log, this doesn’t necessarily imply that IC is faulty but also that it cannot be reached by the device which wants to read/write it.Address bus is shared among the two MASK ROMs @3K and 7K, doing a check with my muktimeter all was fine except for pin 42 of both, I got no continuity between them :
Pin 42 is the higher address line:
I simply ran a jumper wire, this restored sprites and fixed completely the board:
Received this faulty Parodius DA! PCB for a repair:
The fault concerned the graphics, there were jailbars all over the screen :
Clearly the tilemap generation circuitry was involved, this is made of two 4Mbit MASK ROMs and two ASICs that work in parallel : the ‘052019’ generates the address lines and the ‘051962’ receives the data from the MASK ROMs and process them :
The MASK ROMs check reported the two devices @K13 and K19 (containin tiles data) as bad:
The MASK ROMs @K19 was already removed and socketed.I dumped the device and my programmer warned about a poor contact of pin 13 (data line D0)
Replacing it with a 27C400 produced very little improvements, the test still reported the two bad MASK ROMs.This meant the main CPU could not reach the two devices (thru the ‘052019’ ASIC) so I went to do a continuity check.All the address lines should be daisy-chained between the two 4Mbit MASK ROM and the ASIC but I found some broken/bad contacts from the one @K19, whoever replaced the device managed to break some connections.Here the solderside overview:
Here are some close-up (taken with a microscope) of the invoved pins (pin 1-5-13)
I restored the connections but still got jailbars:
Chcking the data bus of the tiles MASK ROMs I found a bad via which should have tied pin 29 (data line D19) 0f the device @K19 to the near ‘051962’ ASIC (which processes the tilemap data)
Patching it restored completely the graphics.Job done.
PAL UpdatesComments Off on Hi-Lo ALL-LAB base unit PAL dumps added
May132017
I recently bought myself a Hi-Lo ALL-11 programmer. This unit uses the original ALL-LAB base unit to connect to the outside world and also as a power supply.
Inside there are four PALCE16V8 chip. Three of them are already dumped and are out in the wild HERE
The one at U9 is registered and there cannot be recreated using our usual methods. I suspect this is also why it hasn’t been dumped before.
As the device is a PALCE there is a good chance I could reset the security fuse using my Runfei programmer. This was successful and I was able to read out the fusemap without any issues.
The registered part looks like a 4 bit binary counter and the equations show that too so I am going to mark this as ‘Assumed Working’ for now. I haven’t tested as I really wanted to get the programmer back together for some playing around with.
All the ALL-LAB PAL’s are now dumped and a copy has also been sent to the site above for inclusion.
