New dump of KD29B added
 PAL Updates  Comments Off on New dump of KD29B added
Dec 212017
Today I’ve added a new dump of the KD29B PAL from King of Dragons on CPS1.
The original dump was taken from a seemingly unlocked device but was dumped as a GAL16V8 instead of a PAL!6L8 which may have caused issues.
Anyway, I’ve recently had the opportunity to study this chip and have what I believe to be a more accurate version.
 Posted by at 4:06 pm
Dogyuun repair log #1
 PCB Repair Logs  Comments Off on Dogyuun repair log #1
Dec 192017
Got from Portugal this almost mint but not working Dogyuun PCB, a shoot ’em up released by Toaplan in 1992:
On power up, after the system got initialized, board sat on a black screen.Main 68000 CPU was halted at this point,no sign of activity on all busses and control lines:
Usually this happens when a device (most of times RAMs) in the CPU address space doesn’t answer to initial check.So I went to probe RAMs and found that the two Mitsubishi M5M5178 @U46-U47 (8k x 8bit static RAM compatible with 6264) had /OE and /WE lines stuck (they are addessed by one of the GP9001 ASIC so the are VIDEO RAMs)
When I went to piggyback the one @U47 the board successfully booted and entered in game:
The chip obvioulsy failed the out-of-circuit test:
The game was fully playable but while testing I noticed some of the player 2 inputs didn’t work, in particular LEFT RIGHT, BUTTON 1 and 2 were responding at same time when one of them was activated.This can be clearly seen in the input check of TEST mode:
Checking with a logic probe the relevant pins of the  JAMMA edge connector revealed that they were floating when usually they must stay in HIGH state when not activated (and then LOW when input is activated).Pull-up resitors or resistors array are used most of times to keep the inputs in HIGH state.When I went to check with a multimeter the 4.7K array @RM7 I found no reading from pin 5 onwards :
So it was most likely internally cracked.Indeed, once removed, it fell off in two parts:
Fitting a good one cured the issue.Board 100% fixed.
 Posted by at 5:01 pm
Dangerous Curves PALs added
 PAL Updates  Comments Off on Dangerous Curves PALs added
Dec 102017
Muddymusic sent me a Dangerous Curves PCB which has a load of unlocked PALCE16V8 devices on it.
I dumped them all using my programmer.
The PCB is a non worker so I cannot test these but they are assumed working at this point.
Thanks to my good friend Muddymusic for this
 Posted by at 12:06 pm
TH Strikes Back repair log
 PCB Repair Logs  Comments Off on TH Strikes Back repair log
Dec 102017
Received from Uruguay this ‘TH Strikes Back’ PCB (a.k.a. Thunder Hoop 2 by the spanish Gaelco)
Board played with all the graphics scrambled and messed up:
Doing a visual inspection I found a severed trace on solder side:
Patching it restored graphics but playing the game I noticed that the sound samples were all wrong and played randomly:
Samples are generated by the usual OKI MSM6295 PCM chip, given the high rate of its failure I went straight to replace it:
This gave me correct sound.But while testing the board, it suddenly committed suicide:
Like many other Gaelco boards this PCB uses for protection a Dallas DS5002 MCU which executes code stored in battery backed-up SRAM.When the contents of the SRAM get lost due a low battery or other problem the board will no longer boot showing on boot the “COPROCESSOR NOT READY” or “COPROCESSOR BAD” error:
Thanks to the work of MAME devs (Peter Wilhelmsen and Morten Shearman Kirkegaard) who dumps the contents of the SRAM now we can revive most of the Gaelco boards.The usual procedure to do it is well known and can be found on the net but it won’t work for some games that use a special register like Thunder Hoop 2.I was warned of this by Peter Wilhelmsen himself, he explained me how to properly desuicide this board (I will cover this topic in a proper post).I did it and board booted again but freezed everytime I started a game:
This issue had nothing to do with the Dallas DS5002 MCU, board was properly desuicided so I started to look elsewhere.Using a logic comparator in 68000 main CPU area I found a 74LS373 @D16 (involved WORK RAMs addressing) with a stuck LOW output (PIN 6).Measuring resistance to ground of this pin gave me only 10.9 Ohm sign that internal junction was almost shorted :
Once removed the TTL it failed the out-of-circuit testing in that exact pin:
Fitted a good TTL fixed the board definitively.Thanks again to Peter Wilhelmsen for his precious help.
 Posted by at 9:47 am
1941 : Counter Attack repair log #2
 PCB Repair Logs  Comments Off on 1941 : Counter Attack repair log #2
Dec 092017
Got this 1941 : Counter Attack (Japan release) B-BOARD for repair:
Game had some graphics issue on backgrounds:
I swapped the C-BOARD with the one from a Street FIghter II : World Warrior which mounts the same ‘CPS-B-05’ ASIC :
GFX issue disappeared so the fault was in the C-BOARD :
I was asking by owner to transplant the ASIC from the donor C-BOARD to original one, here’s a step-by-step collage:
The operation was successful :
Board 100% fixed and aesthetically like genuine, appearances count too…
 Posted by at 4:47 pm
