Konami Viper repair log
 PCB Repair Logs  Comments Off on Konami Viper repair log
Feb 142018
I’ve been playing around with a couple of Konami Viper PCB’s that Olly sent me recently.
The idea was to get a working PCB for his Silent Scope Fortune Hunter.
This board set was non booting and a quick visual inspection showed some signs of ‘man-made’ damage.
First was the 3793-A voltage sense IC was a bit mangled which had lifted most of its traces. Chances are this was causing the PCB to not boot as this chip is responsible for making sure the voltage levels are what they should be.
As its a small pin count it was fairly easy to patch up the traces.
The second issue was the DS2430 IC has been removed. Luckily this was provided in a small bag so I was able to refit it (after dumping it). This IC is in a TO-92 package and is responsible for providing one aspect of the security on this hardware. I never took any pictures of this but its only 3 legs to solder and there was no damage.
After dealing with these the PCB booted right up
Taking pictures of this was really hard due to the amount of glare my cheap screen gives.
From here I can get the game to boot up but I cannot test beyond that. I will send this PCB back to Olly and hope it works out for him.
 Posted by at 3:33 am
Sunset Riders repair log #7
 PCB Repair Logs  Comments Off on Sunset Riders repair log #7
Feb 102018
Still another “portughese” PCB, a Sunset Riders :
The board was unstable, most of times it didn’t boot and kept resetting (watchdog active), some times after some reboots it got past the self-test and entered in game but sprites were missing.If I pressed/flexed the board, they appeared.Here’s a video for a better understanding:
I noticed someone previously tried to fix this issue by reflowing the two sprites generator ‘053244’ and ‘053245’  (forgetting to remove flux residuals )
The reflow was done properly but it was not enough, anyway there was for sure a bad contact in this area. At a closer inspection I found that a pin of the near ‘054358’ custom had its pad detached from PCB, this caused intermittent contact with its trace.Here’s a close-up under a microscope:
I promptly restored the connection, in this way the board booted all the time with sprites too.But playing the game I noticed some little glitches :
The glitches got worse if I put my fingers on the solder side of the two palette SRAMs (2K x 8-bit devices)
The one @14D was already replaced and socketed, probing the other one @13D with a scope revealed unhealthy signals on some data pins  :
This lead me to remove the device and test it ouf-of-citcuit where it failed:
Replacing the RAM fixed board completely, another successful repair in the archive.
 Posted by at 11:07 pm
Aliens repair log #4
 PCB Repair Logs  Comments Off on Aliens repair log #4
Feb 092018
Got always from Portugal this Alien PCB:
As often happens on this hardware the sprites had jailbars thru:
Board uses 4Mbit MASK ROMs to store GFX (sprites and background) data that are quite prone to failure.I launched a MASK ROM check that reported a bad device @K8:
I removed it and my programmer warned me about pin 13 (data line D0).I tried the dump in MAME and I could reproduce the issue :
I replaced the MASK ROM with an equivalent 27C400 EPROM :
This fixed issue and board completely.End of job.
 Posted by at 10:56 am
Bomber Man World repair log
 PCB Repair Logs  Comments Off on Bomber Man World repair log
Feb 072018
Received from Portugal a batch of faulty PCBs for repair, there was among them this Bomber Man World (on Irem M97 hardware)
The PCB was working fine except for the sound, you could only hear some scratchy noise and also video output was affected showing some kind of disturbs:
This is scenario I faced many times during repairs and the cause was always the same : the electrolytic capacitors.In particular Irem boards suffers from the “brown ELNA” syndrome and this was not an expection.I  went to measure capacitors with my ESR meter starting from the 470uF 25V one @C203 which filters the +12V routed to to sound amplfier.My meter didn’t display any reading meaning the measured ESR value was out of range (from 0 to 99 Ohm on my meter)
Probing the +12V line with a scope confirmed there was some ripple (no longer filtered by this capacitor)
The out-of-circuit testing  confirmed the high ESR and bad capacitance :
Fitting a good capacitor restored loud and crisp sound.End of job.
 Posted by at 6:34 pm
Hammerin’ Harry PAL dumps & Warriors of Fate PAL dumps
 PAL Updates  Comments Off on Hammerin’ Harry PAL dumps & Warriors of Fate PAL dumps
Feb 072018
Today Hammy sent me 3 PAL chips.
We have one from the M84 Hammerin’ Harry, this one is very similar to the one we already have but it has a “-D” appended to the label ID. Next one is from the M72 Hammerin’ Harry and the PAL from Warriors of Fate on CPS1.
The Hammerin’ Harry ones have been tested by Hammy.
Thanks to Hammy for sending these.
 Posted by at 4:12 pm
