Rolling Thunder 2 repair log
 PCB Repair Logs, Repair Logs  Comments Off on Rolling Thunder 2 repair log
Jul 112018
Got this game for a repair.
At boot it displayed the following:
Using Mame source code with the memory map I could narrow down that RAM0044Eo20 was the colour BLUE ram
Desoldering it I could confirm it was bad
After replacing it I still got:
30TIP, 31TIP and 33TIP error
After discussing with Charles MacDonald he pointed me to the DUAL PORT RAM.
It checks if the last entry in RAM (460FFF) is zero, if so that’s an error (should be non-zero)
Then it checks if 460FF contains byte 6B, if it doesn’t that’s an error too
I started to probe around the dual port ram
Until I found a stuck bit on the Left side of the Dual port ram which came from a 74HC175.
After changing it, the game booted but still with TIP33 error which could be erased by pushing the start button.
TIP33 is the error related to the EEPROM which is not inizialized correctly or contain some corrupted data. Normally you inizialize it only one time but everytime
started the pcb, I got this error and offcourse all the dipswitch settings couldn’t be saved correctly.
To cut a long story short, some smart guy changed the original EEPROM with a normal 8k SRAM!
I took a spare from a faulty final lap 3  and I could finally fix 100% the game
Black Tiger repair log #3
 PCB Repair Logs  Comments Off on Black Tiger repair log #3
Jul 012018
Although this is a bootleg it follows the original PCB closely.
Couple of easy fixes on this one.
First a character issue and second a sound issue.
As you can see in the video above, the screen is filled with “A”s and none of the text is correct
There is a seperate EPROM used for characters on this game.
Pulling this and reading back with my programmer yielded a valid dump for Black Tiger.
Checking the adjacent associated 74LS273’s and 74LS245 showed I had at least one pin floating.
I traced this back to a nearby TMM2016 which had D7 floating.
Replacing this fixed the screen
The sound issue was even easier. The sound program EPROM was completely smashed. Replacing it fixed the issue.
Job done.
 Posted by at 11:49 am
Taito MB112S146 custom reproduction
 Reproductions  Comments Off on Taito MB112S146 custom reproduction
Jun 122018
Recently I have been working on reproducing the MB112S146 custom chip for my friend BanjoGuyOllie.
This module is found on Arkanoid, Darius and probably some other titles too.
This has now been done and is available in the downloads section. It required the adapter board from ColinD but I will soon compile for MikeJ’s module too.
So far its only tested on Arkanoid but probably will never get a chance to test on other hardware.
 Posted by at 7:39 pm
PLD Archive news
 General  Comments Off on PLD Archive news
Jun 102018
The PLD Archive is currently in the process of being moved to a new wiki.
There may be a delay is adding new files while the wiki get populated. This is currently over half way done but the process is long and tedious bear with us.
In addition to the normal PLD files there is also scope to add more detail and pictures so if anyone has any good quality PCB pictures or extra information like missing PLD IC location details or names then please let us know.
 Posted by at 9:18 am
Cabal joystick sub board reproduction
 Reproductions  Comments Off on Cabal joystick sub board reproduction
Jun 102018
This is a simple reproduction I made of the joystick sub board you can find on Cabal PCBs.
I kept the original design of the original sub board which is this:
With the only difference I put the 74LS244 on top of PCB:
The reproduction is something not really great perhaps, someone else already made it it the past like Elgen:
https://elgensrepairs.blogspot.com/2013/04/tad-cabal-trackball-to-joystick.html
But it’s useful if you want to convert a Cabal PCB from trackball to joystick version using at same time the proper ROM set.
That’s all, simple but effective!
 Posted by at 9:17 am
