PCB Repair LogsComments Off on The Simpsons double repair log
Jul242018
Received from Portugal a couple of faulty The Simpsons PCBs.The first one:
When powered the board up I experieced sprites issue, some parts were missing:
The MASK ROMs test reported three bad 8Mbit devices which store sprites data :
This was almost unlikely so further investigation was needed.All the sprites generation is accomplished by two ASICs : the ‘053246’ which generates addresses to the MASK ROMs and the ‘053247’ which reads their data.But, unlike other Konami PCBs with similar design, the data lines of the MASK ROMs are not directly tied to the ‘053247’ but some 74LS373 octal d-type latches are in the middle (two of them receive the whole 16-bits of each MASK ROM)
I opted for a ‘shotgun method and replaced all of them.The MASK ROMs check no longer complained and reported all devices as good:
Board completely fixed:
The second PCB:
The board was failing the POST reporting two bad devices @6G and 7G:
They are respectively the ROM and the RAM of the Z80 audio CPU circuit .
The 1Mbit ROM was socketed so I pulled it and found that one leg was missing:
I rebuilt the leg and dumped it in my programmer but I got inconsistent readings so I replaced the device.In this way the board booted into game but graphics were wrong.The sprites were missing as well as the backgrounds incomplete and with bad colors:
I ruled out the MASK ROMs by performing a check :
At this point there was not much to test, graphics generation is entirely accomplished by custom ASICs.There is one especially whose functions could be related to the issue :
The ‘053251’ is a priority encoder which takes on input different layers of graphics as well as some priority bits and outputs 11 bit of palette index plus two shadow bits (info taken from MAME source)
Probing the output pins with a scope revealed weak signals on most of them:
I removed the IC preparing then the area to accomodate the spare part:
PCB Repair LogsComments Off on Toaplan (Vimana – Out Zone) double repair log
Jul222018
I’ve been sent from Portugal a box of faulty PCBs for repair with some Toaplan stuff inside like Vimana and Out Zone (both japanese revision)
Vimana :
Board was booting and played fine except for some little glitches on background:
Backgrounds data are stored in four 28 pin 1Mbit MASK ROMs:
Devices were dumped fine except the one @ROM3 which gave inconsistent readings.Loading the file into MAME emulator reproduced the issue exactly:
I replaced the faulty MASK rom with a 32 pin 1Mbit non-JEDEC EPROM (adding the missing sockets)
Board 100% fixed:
Out Zone :
Board booted but sprites were garbled :
Probing a row of RAMs revealed /CE pins on three of them (the two 6264 @13A-14A and the 6116 @16A) were receiving no signals :
At a closer inspection I found a burnt trace going under them:
I removed two of the three involved RAMs:
Tracing back the burnt trace I figured out it was a GROUND signal that should have been daisy-chained to the /CE lines (grounding also address lines A10-A9-A8 of the 6116) of the three RAMs enabling the chips.A couple of jumper wires did the job:
ReproductionsComments Off on Konami ‘054574’ reproduction
Jul202018
The ‘Konami 054574’ can be found on some PCBs from this japanese manufacturer always along with the three RGB DACs ‘054573’ (see past article for this ) so this reproduction is the natural follow up.
It shares the same SIL package and pin counting :
As well as most of the internal circuitry with open collector buffers, R/2R and transistors:
Its functions are not really clear though, for sure it’s connected to the above mentioned ‘054573’ and the ‘054338’ (which is a color mixer for special effects) so possibly it’s a RGB mixer/filter.
I simply reproduced it at ‘low-level’ identifying all the parts with their values and figured out the circuit schematics.Here’s the result .
Testing was successfully carried out on a Wild West C.O.W.Boys of Moo Mesa PCB :
ReproductionsComments Off on Konami ‘007593’ & ‘007327’ reproduction
Jul142018
The ‘007593’ and ‘007327’ are two custom ICs found on some PCBs manufactured by Konami in end 80s.This should be a complete list:
‘007593’ on :
Black Panther
Fast Lane
Contra / Gryzor
Hyper Crash
Salamander/Life Force
City Bomber
Kitten Kaboodle / Nyan Nyan Panic
Labyrinth Runner/Trick Trap
Vulcan Venture / Gradius 2
‘007327’ on :
Combat School /Boot Camp
Rock ‘n Rage
Jackal/Top Gunner
Flak Attack
Devil World / Dark Adventure
Double Dribble
Rack ‘Em Up/The Hustler
Haunted Castle
Super Contra
Battlantis
Blades of Steel
Ajax
MX5000
Both ICs have strong similarities starting with how they appear:
Analogous package apart, they have same function as we can see from schematics:
But the ‘007593’ and ‘007327’ are not simple RGB DAC as you can think of at first glance but they embed a complete palette color circuitry on a single chip.So not only RAMs but, as you can see, many other ICs in form of bare dies covered by coating as well passive parts :
Therefore, for this reproduction project I used a different approach.I studied previous Konami hardware figuring out how the color palette circuit was engineered without the use of the customs.After drawed my schematics I reproduced the ‘007593’ for first:
Once successful tested, it was the turn of the similar ‘007327’ :
Testing on their respective boards:
The layout of both reproductions could be surely optimized (with consequent reduction of the size of the board) using moderm complex programmable logics but I’m happy enough with them since my primary goal was to study a working replacement for these two custom ICs which seems quite prone to failure making our beloved PCBs unusable.
