Who of us has not played at least once Xevious?
Xevious is a vertical scrolling shooter arcade game that was released by Namco in December 1982.It runs on Namco Galaga hardware. In North America, the game was manufactured and distributed by Atari.
I had on my bench the Namco version:
Board booted correctly, game was fully playable but sprites were missing some lines and also playfiled got some issues:
All GFX customs (the sprite positioner ’12XX’, the object RAM addresser ’04XX’ and the GFX data shifter and mixer ’11XX’) were OK since I swapped them with ones of my Galaga/Gaplus boards.Luckily Namco released schematics for this board so for first I checked the part of circuit involved.All was good until I come across this section:
As you can see there are six 74LS161 counters that take DATA from one 2128 SRAM @2S (addressed by the custom “04XX”):
Three 74LS161 address two of the four 2149 RAMs @5M and 5N:
When I went to probe the two 2149 RAM @5N and 5M I found four address lines (PIN3-6) stuck LOW.As I said before, these are addressed by a counter @5S so I went to use my HP10529A logic comparator on it.All led corrisponding to outputs turned ON while all inputs were correctly working.Desoldered and tested it out-of-circuit confirmed it was bad:
Fitted a good 74LS161 restored correct graphics.
With this repair we conclude the May season of logs.See you hopefully next one!
