Namco ‘CUS98’ reproduction
 Reproductions  Comments Off on Namco ‘CUS98’ reproduction
Sep 102019
As someone may recall I’ve recently done a reproduction of the custom ‘CUS99’ used on Namco PCBs :
Namco ‘CUS99’ reproduction
After done it I thought it was good to take into account its “companion” too, the ‘CUS98’  which most times come along with the first.Package is pretty the same but with two further pins than ‘CUS99’
But functions are totally different and,  as Rolling Thunder schematics suggest,  the main one is to generate the master reset :
Secondary functions are coin counters and lockouts handling as well as lamps driving, it seems only few games (like Pac-Land and Gaplus) use this last feature :
I was obviously interested in reproducing at least the reset generation function which is essential for correct operation of the PCB  (but it seems Rolling Thunder can boot into game also with a missing ‘CUS98’).Therefore, as usual, I studied earlier Namco hardware where the custom had not yet been used and I came to a prototype developed on a breadboard:
The protoytpe worked pretty good :
Hence I developed a proper board :
Final testing on a Pac-Land PCB:
As said some functions have been intentionally omitted favoring the needed ones (watchdog circuit ad reset switch were implemented too).This will at least allow to save PCBs with a faulty/broken or missing ‘CUS98’.
 Posted by at 8:10 am
PLEASE READ
 General  Comments Off on PLEASE READ
Sep 082019
Please note that there are multiple contributors to this site and each has their own individual views and opinions and they are NOT necessarily the views and opinions of other contributors.
Each persons work shown on here is their own.
 Posted by at 11:10 am
Rapid Hero repair log
 PCB Repair Logs  Comments Off on Rapid Hero repair log
Aug 292019
Got for repair this original Rapid Hero PCB, an obscure vertical shoot ’em up released by NMK in 1994 and a very sought-after board :
The board booted up but some sprites were affected by jailbars :
Besides, an entire music track was missing or sometimes corrupted as well as some sound effects:
The board had some sign of previous repair on solder side :
This is the area of the ‘CN1’ and ‘CN2’ connectors where the ROM board, which contains all the game code and data, plugs into the mainboard:
The repairs let assume a weakness and subsequent failure of the headers connections probably due to repeated disconnections and insertions of the ROM board.So I checked with a multimeter in continuity mode all the traces from the ‘CN1’ header and found another broken one that I promptly patched :
This fixed the graphics, no more jailbars on sprites :
Now the sound issue.
The audio circuit was previousy reworked, one of the OKI MSM6295 was likely replaced and one trace was repaired but this was not the culprit :
I noticed that if I pressed the ROM board on the ‘CN2’ connector some of the missing sounds were restored.I checked traces from ‘CN2’ to mainboard and found two missing connections to the ‘NMK112’ custom ASIC (responsible of  bankswitching the sample ROMs of the two OKI6295 ADPCM chips)
I patched the traces with some AWG30 wire:
Sound was totally restored and board 100% fixed.Repair accomplished.
 Posted by at 10:57 am
Apple IIe repair log – bad ram
 Computer Repair Logs, Repair Logs  Comments Off on Apple IIe repair log – bad ram
Aug 262019
I recently received this Apple IIe PCB from the U.S to try my luck on salvaging the 60hz IOU and using it in my International NTSC board in the hopes of getting colour which I did successfully in my previous post. This board was advertised as untested, so that normally means “DEAD” and I assumed so.
Taking one look at the RAM suggests there were issues in the past and most likely still issues. We have some original mT ( Micron ) / Apple branded DRAMs mixed in with the various replacements. Micron don’t exactly have the best reputation in regards to reliability so this is definitely a red flag. These were used by Commodore, Atari and obviously Apple as well. I guess they were cheap!
Based on the excellent condition of the board I was happy and confident in firing it up. It displays some kind of RAM error but it’s not very helpful, definitely not as helpful as the reporting in the Enhanced IIes built in diagnostic. I don’t have a choice but to go through and check each DRAM individually.
My TopMax helps me find 4 bad DRAMs of the 8. Three of which were Micron ( expected! ).
Dead RAM chips on the left clearly marked  to remind me that these are dead and not to be mixed up with working. These will come in useful for refining my Atari 8bit diagnostic tool.
I temporarily replaced the dead RAM chips with known good Micron pulls from my friends Atari 800xl. But I do have some NOS TMS 150ns chips that will be going in shortly.
Replacing the RAM confirms the fix.
It’s nice to have a second board ready to go if I need it, and the fact that it’s a non enhanced board with everything socketed is a plus.  I’ll be looking at converting this over to enhanced at some point via a enhancement kit which involves a 65C02 and newer roms for Apple IIc compatibility.
Apple IIe enhanced ( Platinum ) – NTSC 50hz to 60hz conversion
 Computer Repair Logs, Mods, Repair Logs  Comments Off on Apple IIe enhanced ( Platinum ) – NTSC 50hz to 60hz conversion
Aug 252019
The final revision of the exported Apple IIe and Platinums use the International NTSC PCB, this ships with a very odd 50 hz NTSC configuration. The stock motherboard is fitted with a 14.238Mhz and requires the original 50hz Apple IIe Color Monitor to display a non monochrome picture on the screen. A standard 60hz capable NTSC monitor or 50hz PAL monitor ( as expected ) fails to pickup the colour on these machines due to some odd Hybrid combination.
Unfortunately my Apple Color monitor has a dead flyback and all efforts to source a replacement or substitute part went nowhere so I had to find an alternative. One alternative is using a PAL / Color encoder card but these are rare and expensive whenever they turn up.
The theory to get colour involves changing the crystal at Y1 from 14.238Mhz to 14.31818MHz, this is logical and seems to work for most people who have tried this modification. One of the issues surrounding the crystal has already been discussed at length on the various forums, it must have an ESR of 25 ohms and not any off the shelf crystal will do apparently. Most people have had success using the specific type of crystal with the right characteristics, unfortunately I have not. After changing the crystal at Y1, I still had a black and white display on all my monitors ( Sony PVM, Philips & TEAC LCD  ) which are capable of displaying 60hz NTSC in colour.
The PVM and my Commodore 1084s PAL monitor ( Philips made ) had no issues with locking on to sync despite the black and white monochrome picture ( expected in the 1084s case ). My Philips LCD still interpreted the signal as PAL even after changing the main crystal. In fact the signal was not stable and both LCDs were struggling to lock on to sync permanently, with the picture slightly shimmering or going completely out of sync for at least half a second ( as in the TEAC’s case ).
This has left me scratching my head as it appears that ALL my monitors were very picky , yet other people had success.
The Technical Reference Manual, in chapter 7 states that the IOU ( input / output unit ) handles and generates the video signals, video blanking, horizontal  signals via some internal counters.
http://www.applelogic.org/files/AIIETECHREF3.pdf
There are several different versions of the IOU but information out there is rather confusing and in some cases incorrect and that’s something I’d rather not cover at all. The NTSC International and even the PAL models use a very specific version of the IOU not found in the non export, U.S versions.
  • IOU 344-0022 ( used in International NTSC 50hz and PAL models ).
  • IOU 344-0020 ( NTSC 60hz ).
I had an idea to swap out the original 344-022 IOU for the 344-0020 and I took my chance on a non tested earlier IIe PCB.  Thankfully only 4 RAM chips were bad ( mostly Micron, surprise surprise! ) which I’ll cover in my next repair log. I very carefully remove the original IOU, installed a machined pin socket and swapped the IOUs over. The original IOU still works in the other IIe after all that surgery ( Phew! ).
At some point later on I had to replace the RAM as well most likely caused by accidentally handling static prone devices without an anti-static wrist strap ( whoops! ). Not to worry, I have plenty of spares.
The results with splendid colour on my PVM!
And a valid NTSC signal on my Philips LCD ( Karateka in action! )
Conclusions: It was suggested the possibility that the original IOU was damaged or partially faulty ( I have to keep that in mind ) but I’ll never know unless someone else confirms the same or I can get my hands on another IOU ( 344-0022 ). I previously had the same exact issue in another IIe before I sold it, however I was using FOX143-20 branded crystals ( which have an ESR of 40 ohms ) at the time rather than the proven to work ones below which have an ESR of 25 ohms.  I still have my FOX crystals on hand, so at some point I’d like explore those again and see if colour is still possible given I’ve swapped the IOU over to the 60hz version.
The following crystals have been proven to work.  Still no colour on your International NTSC board  ? Try a different IOU by substitution.
ECS-143-S-1
ECS-143-S-1X.
These can be found at the link below.
https://www.digikey.com/products/en?keywords=ECS-143-S-1
