Ken-Go repair log
 PCB Repair Logs  Comments Off on Ken-Go repair log
Nov 052015
I had this rare Irem Ken-Go PCB (an undumped version included in latest MAME release) from my friend Joachim for a repair:
Ken-Go_PCB
The board played fine except for an issue where all sprites were formed but missing all colors appearing like black shape:
sprites_issue
Sprites generation circuit is located on top board where some customs lie:
Ken_Go_video_board
Documentation for this specific game was not available but luckily I could know function of the various customs by looking at the R-Type schematics and so identity the one involved in the sprites palette generation:
sprites_circuitry
The custom itself was marked ‘KNA91H014’ in 60 pins QFP package:
RSCN0698
Probing it revelead that inputs were fine but outputs had irregular signals:
KNA91H014_output
So I opted for replacing this custom (taking a good one from a dead Vigilante board)  :
KNA91H014_replacing
This was the right move since sprites were correcly restored:
sprites_fixed
End of job.
 Posted by at 3:57 pm
Haunted Castle repair log #1
 PCB Repair Logs  Comments Off on Haunted Castle repair log #1
Nov 042015
Got this Konami Haunted Castle PCB for a repair:
Haunted_Castle_PCB
When I powered it up for first time, two were the faults I noticed : sound and sprites were missing.So I started to troubleshoot first issue.The sound circuitry of this hardware is made of an Z80 CPU,a 6116 SRAM, a 27256 ROM and YM3812 DAC plus a couple of custom for PCM samples and music generation (K007232 and ‘K051649’).When I went to probe the Z80, I found that most of data lines were stuck LOW or HIGH.The ROM containing sound code was good as well as the relative RAM.With the help of schematics I figured out that sound code data were latched by a 74LS374 @G11 :
sound_circuitry
Probing its outpus revealed they were stuck and piggybacking it caused playing some random samples.So I decided to remove the IC :
74LS374@D11_reworking
It failed when tested in my programmer:
74LS374@G11_failed
Sound was fine but, as I said, sprites were missing (except for some):
Since I already repaired in the past a couple of Haunted Castle boards with identical issue, I knew where to look at.Hardware uses for sprites and tiles some 4464 DRAMs in ZIP package.In particular the two related to sprites are the ones @H3 and @H4:
M5M4464L_sprites_RAM@H3_H4
So I ordered some spare parts from China.When they finally arrived , I could successfully finish my job by replacing them:
M5M4464L@H3_H4_reworking
Another great game preserved!
 Posted by at 4:19 pm
Capcom CPS-B-01 C-BOARD repair log
 PCB Repair Logs  Comments Off on Capcom CPS-B-01 C-BOARD repair log
Nov 032015
Just a quick (but quite important) fix.Got from my friend Josef this spare Capcom C-BOARD with CPS-B-01 ASIC on it:
CPS-B-01_C-BOARD(1)
Whatever game I tried with it, I got sprites issues.Strider for example:
Strider_sprites_issues
I was pretty sure the CPS-B-01 ASIC was bad, it’s very prone to failure IC but I decided to have a look at it.Doing a continuity test with my multimeter on solderside of the C-BOARD I found two broken traces:
broken_traces_1
I promptly patched them with some AWG30 wire:
patched_traces
This restored correct sprites:
fixed_sprites
 Posted by at 10:03 am
SEGA Mega Play PAL dumps added
 PAL Updates  Comments Off on SEGA Mega Play PAL dumps added
Nov 022015
Today, after repairing it, I dumped the PALs from a Sega Mega Play PCB.There were six devices, I was able to reverse three of them, one was already dumped by Porchy from a Mega Tech PCB.The remaining two use latches so a deeper analysis is required.
 Posted by at 3:04 pm
SEGA Mega Play repair log
 PCB Repair Logs  Comments Off on SEGA Mega Play repair log
Nov 022015
My friend Joachim sent me this Mega Play system for a repair:
Mega_Play_motherboard
The Mega Play is the name of a JAMMA-based arcade boardwith the ability to run Sega Mega Drive games. It was the second attempt by Sega to bring the home console to the arcades, following the Mega-Tech arcade system.Games come in form of cartridges:
Mega_Play_cart
At power up the system booted but got stuck on the welcoming screen not loading cart in whatever slot was inserted:
screen_stuck
As I said, this system operates on the same core components that the Sega Genesis uses (plus some additional hardware, such as an additional Z80 and Master System VDP for driving an optional second monitor that displays a list of games installed).In particular there are two VDP  (Video Display Processor) custom chips marked ‘315-5433’ and ‘315-5313’.When I went to inspect them, I found some lifted pins on the latter :
315-5313_VDP
In particular lifted pins were some from 55 to 70 which are directly connected to the 68000 main CPU data bus :
I reflowed these pin and this was enough to fix the board:
fixed
 Posted by at 9:37 am
