Gaplus repair log
 PCB Repair Logs, Repair Logs  Comments Off on Gaplus repair log
Jul 022016
The game belonging to my personal collection didn’t boot anymore after several years kept in storage.
Foto 02-07-16 10 26 28
Game was in mint condition but the address decoder custom 34 had lot of oxidation on the pins (common problem on these custom chips) so I proceeded to clean and reseat it paying particular attention to avoid breaking pins which generally are really weak.
Game booted but it developed the following problem
Foto 02-07-16 10 28 49
After probing around on the rams and TTL for suspicious signals with no luck I decided to dig up my dead Gaplus board which I kept in my garage for Namco customs spare parts and checked one by one each custom.
After changing the CUS20 (tilemap and sprie address generator) the problem was fixed
Foto 02-07-16 10 30 38
Foto 02-07-16 10 26 38
Foto 02-07-16 17 33 44Foto 02-07-16 17 34 11
Another Fujitsu chip left our world.
Nintendo VS System repair log #1
 PCB Repair Logs  Comments Off on Nintendo VS System repair log #1
Jun 302016
In the past days I received this Nintendo VS. System for a repair:
DSCN3625
For the uninitiated the Nintendo VS. System is an arcade platform designed for two-player competitive play using the VS. UniSystem or VS. DualSystem based on the Nintendo Entertainment System.
The system came with his special JAMMA adapter and two game ROM sets installed (Super Mario Bros and Excitebike) so time to power it up and I got this scenario:
wrong_colors
As you can see, screen was all bluish sign that the RED component was missing.This was confirmed by probing the signal, it was stuck LOW on its source which is pin 14 of the RP2C04 PPU @8F :
RED_PIN14_RP2C04
The PPU chip was tested as good in another system so there was something in the path which forced the signal LOW.Before reaching the corresponding pin on edge connector, the signal is converted from digital to analog by a net of resistors and amplfied by a LM324 OP-AMP @1P:
RED_circuitry
DSCN3632
Probing the output pin 8 of this OP-AMP I could measure only +1.4VDC against +10VDC of the output of the other one @3F which is involved in the blue color (which was correctly working)
OUTPUT_LM324@1P_@3F
So I decided to pull out the LM324 and add a rounded machine-tooled socket :
LM324@1P_reworking
When tested out-of-circuit, it failed:DSCN3635
Fitted a new one:
new_LM324_fitted
and red color was restored :
fixed
No further issue were found so board 100% working.End of job.
 Posted by at 3:37 pm
Spectral Vs Generation PAL dumps added
 PAL Updates  Comments Off on Spectral Vs Generation PAL dumps added
Jun 262016
Dumped 4x AT22V10 chips today of my Spectral Vs Generation PCB.
All the chips were unlocked. They may need converted to GAL22V10 format if that is your target device, i’m unsure whether the two formats are interchangeable.
 Posted by at 4:10 pm
Tecmo Knight repair log #2
 PCB Repair Logs  Comments Off on Tecmo Knight repair log #2
Jun 252016
Dug this board out today with the view of selling it.
I put it on to test and also fired up MAME for a comparison and noticed that the digital samples weren’t playing at all. It first noticeable on the attract sequence when the lightning strike and you should be able to hear thunder.
This game uses an M6295 chip in order to deal with the samples so it was really easy to make a start trouble shooting. Using the scope I could see all the inputs and outputs were toggling when I would expect and could see one of the enable lines going active when the thunder sample was meant to play but the DAO pin (pin 36) was just dead. I did try to reflow this just in case but it made no difference.
I replaced this with one from a scrap PCB
20160625_190328
20160625_193803
Sounds are all back now
 Posted by at 8:00 pm
Rainbow Islands – Clock Circuits
 Technical Info  Comments Off on Rainbow Islands – Clock Circuits
Jun 242016
A short simple post on two of the clock circuits used on Rainbow Islands.
There are 3 x crystal oscillators on the Rainbow Islands PCB. This post will cover two of them. The third is used for selecting a chip enable line of some RAM in an elaborate way which I don’t fully understand right now.
First lets look at the X2 Oscillator which is 12MHz.
ri-x2osc
This is solely used as the clock for the C-Chip and simply goes though IC54, an inverter, into pin 20 of the C-Chip at 12Mhz. Easy!
CCHIP
Next up is X1. This supplies the clock signals for the Z80 and the 68000.
ri-x1osc
The 16MHz clock signal serves as the clock signal for a 4-bit binary counter at IC30. Output Q1 (pin 13) of this binary counter gives a 4MHz clock which is the clock signal for the Z80 sound CPU.
Output Q0 (pin 14) of this binary counter gives out the 8MHz clock for the main 68000 CPU.
SCLK
Both of these clocks also feed into the custom PC060HA chip at IC45 on pin 14 (SCLK) and on pin 15 (MCLK).
MCLK
That’s all there is to this one.
 Posted by at 1:00 pm
