Jan 102014
caius has been busy again. This time we have a set of PALs from a Kiki Kaikai bootleg board and the last PAL we have missing from the Super Pang bootleg set.
Kiki Kaikai had no locations silkscreened or ID markings so they have been labelled PAL1-PAL5. There is an image showing the locations which can be found in the archive table.
Also, PAL2 needed to have pin 12 disconnected from the PCB to work. caius has modified the dump so the GAL chip can fit straight in without the need to remove the leg. Both versions are available just in case though.
Thanks again to caius
 Posted by at 5:58 pm
