Jan 252020
This board is a bootleg board but seems to follow the original fairly accurately.
On initial boot up this didn’t do a great deal but then other times it actually started up with various errors.
A fault like this always makes me look at the reset circuit.
This board uses a 6809 as the main CPU and a Z80 as a sub CPU.
The reset pin for the 6809 is pin 37 and using the scope I could see that most of the time it didn’t do what a reset should do.
Tracing it all back I came to this
The reset circuit on this is as simple as it gets really with a capacitor, resistor and diode.
I removed and replaced the capacitor and now the game boots up every time.
Now, although the game booted it appeared to crash when entering attract mode or starting a game with this fault
I remembered Bryan McPhail had the very same issue some time ago and he mentions that the sub CPU needed to be running.
Checking the ROM for the sub CPU I found pin 1 (A15) was dead. Further inspection of the solder side of the PCB I found this
I patched this up as neat as I could and covered it using an overcoat pen
Now the issue was fixed
Last thing to do was deal with the sound.
My initial inspection of the PCB showed the volume pot had been messed with
I removed it and found some bad track damage underneath and on top
I fitted a new pot and patched all this up nicely but I still had no sound.
Tracing it out revealed that the bootleggers mixed up the two SPEAKER connections so SPEAKER+ was connected to SPEAKER- on the JAMMA edge and vice versa.
I spoke to Muddymusic to see what he wanted me to do. The option were hack the board to swap them or make an adapter. The prior option was chosen and I cut the two traces and ended up with this solution.
Now everything works great
 Posted by at 6:53 pm
