Received this Batsugun Special Ver. PCB for a repair:
Game played fine but colors were all dull and washed-out, take a look at this comparison with a MAME snapshot on the left:
or this video:
This was a clear sign of some troubles in colors palette circuitry.After studying the hardware, I was able to locate this section by shortcircuting some address/data lines of two CXK5816 SRAMs @U39 and U40 and at the same time observing color changes on screen:
Besides the two mentioned SRAMs, you can see some 74LS245 and two 74HC273 involved in data bus (the first ones in exchanging data from/to the two RAMs, the latter in latching).When I went to probe the two 74HC273 I found that input pin 13 of the one @U43 was stuck low and its corresponding output pin 12 showed only weak signals:
So confident I went to remove it:
When I tested it out-of-circuit it failed:
Once fitted a good IC and powered up again the board, the game played great with no further issues.
End of job.
One Response to “Batsugun Special Ver. repair log”
You da man!
Good job as always!
