Defender repair log #2
 PCB Repair Logs  Comments Off on Defender repair log #2
Nov 302017
After reparing my Defender ( see this log: https://www.jammarcade.net/defender-repair-log/ ) I noticed that the screen had some horizontal lines of different brightness.
At first I didn’t give much attention but then I decided to look at this issue deeper.
Moving the screen left and right with the monitor commands I noticed these defects:
Having the experience of a similar problem on my Burnin Rubber ( https://www.jammarcade.net/burnin-rubber-repair-log/ ), to me it was clear there was a video blanking problem
With the schematics in hand I found this circuit:
Signals from 7420@5C were good so I started probing the 7400@4B
All signals were good except that pin 10 was floating.
Looking at the above mentioned schematics, pin 10 is tied to the nearby pin 11!
I checked the board and found out that actually the pcb has no trace connected the 2 pins togheter!
No broken traces, it is actually simply not there!
I connected the two pins and…..
Game fixed!
Now I am wondering if my CPU board revision has a production error.
Searching on internet I haven’t found a similar problem therefore I would like to have a feedback from other owners of Defender if their pcbs has the trace or not.
Liquid Kids repair log #2
 PCB Repair Logs  Comments Off on Liquid Kids repair log #2
Nov 302017
Received this Japanese version of Liquid Kids for a repairĀ  running on a different F2 hardware.
The game was playing fine but hadn’t any sounds.
Amplifier and preamps were good so I started to probe the sound circuit logic.
The Z80 sound cpu ram had some weak signals
After replacing it , the sound was restored.
Popeye repair log
 PCB Repair Logs  Comments Off on Popeye repair log
Nov 302017
Quick repair this one.
Received this board recently from a great eBay seller.
It was sold as faulty and indeed it was. On power up I was greeted with this static screen.
As the Z80 is already socketed on these boards I hooked the Fluke 9010 straight up and did a RAM test. As I was expecting, this failed.
The main RAM is located next to the 4 program ROM’s. One socket and one new RAM chip and we have a nice easy fix.
 Posted by at 8:15 pm
Punk Shot repair log
 PCB Repair Logs  Comments Off on Punk Shot repair log
Nov 272017
Some days ago I received this faulty Punk Shot PCB (manufactured by Konami in 1990)
Game had small glitches over the sprites and played mute:
MASK ROMs check reported two bad devices:
Usually jailbars mean some problem in data bus so I went to look at relevant circuit.As in many Konami PCBs the sprites generation circuit is condended in two ASICs : the ‘051960’  which generates the address lines for the MASK ROMs and the ‘051937’ which reads data.Indeed I found a missing connection beetween pin 84 of  the ‘051937’ and pin 28 of the 8Mbit MASK ROM @K7
This was caused by a broken via on solderside:
Patching it restored graphics, MASK ROMs check successfully performed now:
As for lack of sound I quickly pinpointed the fault in a 2k x 8bit static RAM @E6 (connected to Z80 audio CPU). piggybacking it restored sound.Once removed I had confirm it was really bad :
Job done.
 Posted by at 11:12 pm
Haunted Castle repair log #5
 PCB Repair Logs, Repair Logs  Comments Off on Haunted Castle repair log #5
Nov 252017
I got this board for my collection as untested from an arcade operator
Board was the typical Konami pcb manufactured in Italy ( I believe Electronic Devices had a deal with them to import the pcbs and populate certain chips in Italy).
You regognize these boards because they have sound z80 made in Italy , soldered eproms and cheap sound potentiometer
Later on, beginning of 90s they started to put also general “E.Devices” stickers on eproms in place of Konami ones, but at least the eproms were socketed
Back to this board, it booted and the graphic was OK but there was a continuous metallic sound all the time.
Ruled out DAC and OP AMPS because usually when these fails, you have at least either FM or samples working, I started to probe the sound circuit logic following the schematics.
I noticed that the commands from the main CPU were correctly sent to the sound section but as soon as the Z80 had an INTERRUPT request, the CPU didn’t aknowledge it and blocked itself
In particular:
Signal IORQ didn’t go low, thus making the INT signal from the 74LS74 always LOW.
I proceeded to desolder the Z80 and tested it on another game with a socketed CPU and it confirmed to be bad.
While soldering the same Z80 by NEC used on proper Konami assembled boards, I also changed the sound potentiometer with an original Konami taken from another scrap game.
Game was fixed without any other issues.
