Assorted bootleg PLD dumps
 PAL Updates  Comments Off on Assorted bootleg PLD dumps
Sep 162016
Also bootlegs deserve to be preserved so today we have some PLD dumps I got from not original boards (except one)
-Street Fighter II (bootleg)
-Bad Lands (bootleg)
-Power Balls (original by Playmark)
Dumps have been successfully tested in GAL devices.A picture of each board with PLD location has been uploaded as well.
 Posted by at 10:32 pm
Blood Bros. repair log
 PCB Repair Logs  Comments Off on Blood Bros. repair log
Sep 162016
Got this original Blood Bros. among a lot of untested PCBs:
100_8799
For the uninitiated Blood Bros. was released by Tad Corporation in the 1990 and can be considered the sequel of Cabal since it shares the same gameplay.
When I powered up my board, I didn’t noticed anything abnormal but once started a game the background GFX were flashing until they completely disappeared leaving black this part of screen :
Board uses some customs  ASIC to generate GFX.Studying a bit the hardware I figured out that the  one marked ‘SEI0200 TC110G21AF’ 8QFP100)  addresses the  background/foreground 42 pin MASK ROM through some 74LS273 and processes directly its data :
bg_circuit
Piggybacking a programmed 27C800 (equivalent to the 42 pin MASK ROM) had no effect.Since there were no other involved component I was pretty sure the ASIC was bad.Having a Raiden II as donor board I decided to replace this custom:
100_8804
After some work the donor part was in place:
100e8813
Powered up the board again and all the background GFX were back.Board 100% fixed.
 Posted by at 12:00 am
P.O.W. and Blood Bros. PAL dumps update
 PAL Updates  Comments Off on P.O.W. and Blood Bros. PAL dumps update
Sep 152016
In the past day I managed to repair a P.O.W. and Blood Bros. PCBs, this gave me the chance to test the PAL dumps we had in the archive.I could successfully convert the P.O.W. dumps from native PAL format into GAL one except for the one marked ‘P-A8’ which doesn’t work on PCB probably due timing issue.I tested the dumps from Blood Bros. (for some of them there was the need to convert from PAL to GAL format) confirming they are good and dumped a further device so now we have six dumps from this game (there are other two PLDs on PCB but sadly they are secured/registered PEEL18CV8 devices).Lastly, I added correct labels and PCB location.
 Posted by at 3:14 pm
Vigilante PLD dumps tested
 PAL Updates  Comments Off on Vigilante PLD dumps tested
Sep 112016
Today saw Ace’ test the Vigilante PLD dumps we have.
These were previously untested and from an unknown source so its good to actually have these tested now.
Extra label detail was also added.
Thanks to Ace’ for tested and letting us know.
 Posted by at 12:59 pm
Sep 112016
I recently picked up an Apple //e enhanced computer to repair and to relive some memories. Due to the machine’s age ( especially because of the power supply )  I was mindful not to power up the machine and risk damage to the logic board.
I disassembled the power supply and wasn’t at all surprised at what I saw based on what I’ve read, there was no way I was powering this thing on and taking any chances although this was a very high quality power supply compared to power supplies of the same era. This is an astec AA11042C, this version is rated 240v and there were actually two different types available in the Apple ii line. I checked the fuse which looked fine and tested OK with my DMM.
I then removed all electrolytic capacitors and recapped the entire board including the two Rifa filter caps which can fail spectacularly and spill brown coloured goo everywhere. Some capacitors revealed scorch marks on the PCB after removal. The 47uf 250v capacitors from the high voltage side looked fine but were way off spec.
2 bad electrolytic capacitors pulled from the low voltage/output side
A Rifa filter cap. ( Note the cracks! )
Apparently moisture gets inside the cracks and the cap explodes. Not taking any chances, it has to go.
Astec rebuilt with brand new electrolytics & filter caps.
I ended up installing two filter caps made by Suntan, this brand doesn’t have the best reputation in the world but I can swap those for higher quality caps once I get the unit functioning. These were all I could find ( the yellow rectangular looking things near the inductor) and I was so desperate.
I tested the power supply but quickly found out that like all switching supplies, nothing will happen without a proper load or with a short. With the power supply connected to the Apple, nothing happened which was good in a way because I didn’t see any smoke. If I were taking my chances in the same way with an Atari or Commodore power supply then things might have turned out a little different 🙂
There were no voltages present on the logic board of the Apple //e. This prompted me to look deeper. The bridge rectifier ( @ DB1 ) looked a little cooked or oxidized even though it tested good with my DMM, the issue wasn’t there but I replaced it anyway.
Scorched or oxidized bridge rectifier ?
I then started reading a comprehensive troubleshooting guide in the following PDF document.
https://www.applefritter.com/files/Apple2e_Repair_SAMS1985.pdf
I ended up removing a bunch of small transistors, the large power transistor,diodes and re-installed them after they checked out fine. I replaced the SCR ( silicon controlled rectifier ) at scr1 as I have no means to test it. The scr1 shutdown transistor at Q4 tested good. This area is also known as the crowbar circuit which disables the power supply if there’s an over-voltage or a surge, this protects any downstream components like the sensitive stuff in your computer from damage.
I was stumped at this point as none of the above actions solved my problem.
I took another closer look at the PCB and found this burn mark circled in yellow. I removed the 2w resistor which still measured 27 ohms out of the circuit. I re-installed it as it was good.
The above link to the document also mentions to check the windings on transformer T2 and T3 ( PWM control isolator )  for continuity. I remove the smaller transformer ( pictured above, adjacent to the astec silkscreen logo on the pcb ) thinking that I’m wasting my time with this but check for continuity anyway.
There are 6 pins on the bottom of the T3 which are soldered to the PCB. There appears to be 3 separate sets of windings but 1 set of windings had no continuity between two of its associated pins. I found a small break in the winding at the bottom of the transformer ( circled in red ) and soldered it to its corresponding pin. If the break was anywhere else then there would be no way of repairing it, I just got lucky I guess.
I re-assemble the power supply and apply power to the computer and presto. The internal speaker beeps at me and the kb power led illuminates. Failures within transformers are relatively rare but I have just proven to myself that its more likely to happen than I originally thought.
Taking some measurements ( -12v, -5v, 5v & 12v ).
4.97 volts DC, looks good to me!
The red led on the logic board is busted, so I replace it with the only one I have on hand and it’s green.
I also accidentally broke off one of the terminals on the a/c switch due to too much tinkering so I replaced it with one that illuminates. I like it better than the old one.
A backup CRT TV hooked up.
Passes self diagnostic tests
system-ok
That’s pretty much the end of this repair. I do have some issues with the keyboard which are fairly trivial and I’ll address that later when time permits.
References:
1. Apple 2e 6502 Computer Repair Information – SAMS COMPUTERFACTS
