Dark Seal 2 PAL added
 PAL Updates  Comments Off on Dark Seal 2 PAL added
Jun 062015
Also added the last missing PAL from Dark Seal 2/Wizard Fire.
The PAL is a PAL16L8 and is marked as VA-00 at location K3.
It is presently untested but I will get round to testing all of the PALs we have soon.
 Posted by at 2:47 pm
Dark Seal PAL added
 PAL Updates  Comments Off on Dark Seal PAL added
Jun 062015
Today I manually reversed and tested the last PAL we didn’t have from the Dark Seal PCB.
The PAL in question is a PAL16R4 and is labelled TF-4 located at E12.
 Posted by at 1:50 pm
Xevious (Namco PCB revision) repair log
 PCB Repair Logs, Repair Logs  Comments Off on Xevious (Namco PCB revision) repair log
Jun 012015
Who of us has not played at least once Xevious?
Xevious is a vertical scrolling shooter arcade game that was released by Namco in December 1982.It runs on Namco Galaga hardware. In North America, the game was manufactured and distributed by Atari.
I had on my bench the Namco version:
Xevious_PCB_800
Board booted correctly, game was fully playable but sprites were missing some lines and also playfiled got some issues:
GFX_issues_
All GFX customs (the sprite positioner ’12XX’, the object RAM addresser ’04XX’ and the GFX data shifter and mixer ’11XX’) were OK since I swapped them with ones of my Galaga/Gaplus boards.Luckily Namco released schematics for this board so for first I checked the part of circuit involved.All was good until I come across this section:
object_circuit
As you can see there are six 74LS161 counters that take DATA from one 2128 SRAM @2S (addressed by the custom “04XX”):
object_RAM
Three 74LS161 address two of the four 2149 RAMs @5M and 5N:
2149
When I went to probe the two 2149 RAM @5N and 5M I found four address lines (PIN3-6) stuck LOW.As I said before, these are addressed by a counter @5S so I went to use my HP10529A logic comparator on it.All led corrisponding to outputs turned ON while all inputs were correctly working.Desoldered and tested it out-of-circuit confirmed it was bad:
74LS161@5S_testing
Fitted a good 74LS161 restored correct graphics.
good_GFX_
With this repair we conclude the May season of logs.See you hopefully next one!
 Posted by at 9:16 am
