Major Title (IREM M82) PAL dumps added
 PAL Updates  Comments Off on Major Title (IREM M82) PAL dumps added
Jun 072015
Today, after repaired it, I dumped the four PAL16L8 on a Major Title PCB (which runs on IREM M82 hardware).The one marked “MT_A-2H-” @IC5 has same equations of the ‘M81_A-2H-‘ dumped (and tested) by Porchy from a M81 X-Multiply PCB, all other ones seem to be exclusive to this game but could be also shared with other IREM games.All dumps have been successfully tested in GAL16V8 replacement devices.
 Posted by at 10:53 pm
Major Title repair log
 PCB Repair Logs, Repair Logs  Comments Off on Major Title repair log
Jun 072015
Many of you may think that repairing arcade boards is a difficult task but sometimes it’s not so (well, few times though…).Here is an example.
Got an IREM Major Title PCB (M82 hardware) from my friend Corrado (who is part of JAMMArcade team as contributor):
Major_Tilte_PCB
When I powered it up I was greeted from this rolling screen:
no_SYNC_
There was no SYNC at all.I traced this signal back to a 74LS32 @IC14 on video board but, after checked its logic, it seemed good.I noticed there were some socketed ICs both on CPU and video board.Two of them were TBP24S10 PROMs manifactured byTexas Instruments (you can read its specifications in our “datasheet” section).When I pulled of the socket the one @IC47 I got this:
TBP24S10@IC47
PIN16 (VCC) was broken so IC was not powered at all.A little bit of “reconstructive surgery” on this (other adiacent wobbly ones) pin was enough to restore the correct video syncronism (later I found that outputs of this PROM were connected to a couple of custom ICs involved in video timing generation).
fixed
 Posted by at 10:02 pm
Dark Seal 2 PALs tested
 PAL Updates  Comments Off on Dark Seal 2 PALs tested
Jun 072015
Today I successfully tested the PAL dumps we have for Dark Seal 2/Wizard Fire.
Thanks to Elgen for dumping most of them.
 Posted by at 1:53 pm
Kid no Hore Hore Daisakusen repair log
 PCB Repair Logs, Repair Logs  Comments Off on Kid no Hore Hore Daisakusen repair log
Jun 062015
My friend ‘robotype’ sent me some boards for repair.Among them there was this a “Kid no Hore Hore Daisakusen” PCB (キッドのホレホレ大作戦? lit. Dig Dig Kid’s Epic Battle), a pretty obscure (for me, at least) game manifactured by Nichibutsu in the 1987 (released in the Western market as “Booby Kids”):
Kid no Hore Hore Daisakusen_PCB
Board uses, surprisingly for its age, JAMMA pinout so I could power it up without the need of building an adapter as I first thought.Here is all I got, some static garbage:
static_garbage_no_boot
This is clear sign that the CPU is not running so for first  I probed the 68000 main processor.Starting my checking from pin 1 all was stuck LOW or HIGH until I came to CLOCK (PIN15), this was completely silent.I traced it back to a typical clock circuit made of an inverter 74LS04 and a 74LS74 as divider.These ICs were good but when I went further back till to the 16MHz quartz I got this on my scope:
clock_troubleshooting
It was completely dead!Replacing it brought PCB to life again.
PCB_fixed
 Posted by at 5:38 pm
SEGA X board PLD added
 PAL Updates  Comments Off on SEGA X board PLD added
Jun 062015
Some time ago Charles MacDonald sent me a dump of a 315-5280 CK2605 PLD from his Sega X board for a project I was working on.
Anyway, after the project finished I forgot about it until now.
The original device was a CK2605 but it is for use in a GAL16V8. It is untested.
Thanks to Charles for taking the time to dump this for me.
 Posted by at 3:11 pm
