Received this Wild West C.O.W. Boys of Moo Mesa PCB for repair:
PCB was very dirty with flux residual and rust so I first washed it.After dried I powered it up and was greeted by this screen:
The initial self-test reported a bad ROM @T5 and a bad RAM @J4, obviously the board didn’t boot up but kept resetting.Usually Konami testing routines are very reliable so I went to dump the four program ROMs and actually the one @T5 showed at offset 0x3FFB4 a difference of only one byte (well, one nibble..) compared to the MAME dump:
I reprogrammed the EPROM (a 27C020) and error was cleared but obviously the one regarding the RAM @J4 was still present:
RAM @J4 was one of the three RGB 2K x 8-bit palette RAMs :
Piggybacking it had not effect so, before removing the chip in order to test it out-of-circuit, I checked its connections with a multimeter.All was fine until I could measure a short between pin 21 (/WE) of the RAM and VCC :
This explained why the RAM was reported as bad as it was never be written (write enable signal is active low).The /WE signals of the other two RAMs are generated by the near ‘054338’ custom :
so I went to inspect it with a digital microscope and found two bridged pins:
I removed the bridge and board successfully booted but sound was totally missing:
This is a common issue on these Konami board that use the ‘infamous’ hybrid audio module.This board has the ‘054986A’ one :
Usually you can fix this issue by replacing the capacitors but I opted for a drastic solution removing the module and installing two rounded machine-tooled strips with 1.778mm of pitch:
Lastly I used one of my ready module:
Job done.
2 Responses to “Wild West C.O.W. Boys of Moo Mesa repair log #1”
Great repair as always, also I was just wondering if you know if bad caps on the 054986A module can cause the ‘Sound System Bad’ error at start up?
It’s a bucky board in my case but with the same 054986A module, I’m going to recap it anyway but I have a feeling that isn’t the cause of the problem.
I can exlcude that capacitors can cause the “SOUND SYSTEM BAD” error, this is related to digital sound circuit while capacitors are used in analog one.
So the error is due a problem in the digital sound circuit, I suggest you to check all the involved ICs : YM2151, RAM, ROM and obviously the ‘054986A’ hybrid module as well check traces.
