Jan 192017
Sometimes it’s just matter of capacitors…We could call this repair log in this way, let’s read why.
I bought this not working  Vapor Trail – Hyper Offence Formation PCB on Ebay:
The board gave a static blank screen on power up:
Like other Data East games, hardware uses as main CPU a custom 68000 marked ’59’ :
Here you can see its pinout figured out by Porchy some time ago:
Data East ’59’ 68000 CPU Info
Probing it revealed static address/data bus, clock was present instead.Since it was not included in the above pinout I spent some time to figure out that pin 59 was the /RESET one.Probing it I found that on power up there was no transition from LOW to HIGH but pin went directly to HIGH state hence CPU didn’t get initialized.RESET circuit is a typical one made of the PST518 voltage monitor IC, a 47uF 50V electrolytic capacitor and a couple of resistors :
Checking in-circuit the ESR of this 47uF 50V capacitor @IC56 gave no reading, value was out of the 100Ohm range of my meter:
I removed it and out-of-circuit testing confirmed this capacitor was bad:
Replacing it restored a proper RESET signal so board successfully booted:
But sound was quiet despite adjusting the potentiometer and some interferences were present on screen too:
I went to measure the impedance of the electrolytic capacitors in analog sound circuit and I found many of them with out-of-specs value:
I replaced them all :
This restored a loud and a clear sound.As said in the beginning, it was only matter of capacitors!
 Posted by at 7:06 pm
