I’ve been sent from Portugal a box of faulty PCBs for repair with some Toaplan stuff inside like Vimana and Out Zone (both japanese revision)
Vimana :
Board was booting and played fine except for some little glitches on background:
Backgrounds data are stored in four 28 pin 1Mbit MASK ROMs:
Devices were dumped fine except the one @ROM3 which gave inconsistent readings.Loading the file into MAME emulator reproduced the issue exactly:
I replaced the faulty MASK rom with a 32 pin 1Mbit non-JEDEC EPROM (adding the missing sockets)
Board 100% fixed:
Out Zone :
Board booted but sprites were garbled :
Probing a row of RAMs revealed /CE pins on three of them (the two 6264 @13A-14A and the 6116 @16A) were receiving no signals :
At a closer inspection I found a burnt trace going under them:
I removed two of the three involved RAMs:
Tracing back the burnt trace I figured out it was a GROUND signal that should have been daisy-chained to the /CE lines (grounding also address lines A10-A9-A8 of the 6116) of the three RAMs enabling the chips.A couple of jumper wires did the job:
