Aug 212016
Received this original Nichibutsu Terra Cresta PCB for a repair:
100_8608
Board had severe graphical issues, backgounds were all messed up and moving, sprites absent:
The first thing I noticed after my visual inspection was that both boards were fully populated with Fujitsu TTLs therefore I was pretty sure all the faults were due them.To troubleshoot them I used my HP10529A logic comparator for  TTLs up 16 pin and a logic probe for 20 pin ones.The backgrounds data are stored in two 27256 EPROMs @15F and 17F on CPU board so I went to probe around and I found a 74LS273 @18E with stuck outputs:
74LS273@18E_
This was confirmed also by a logic analyzing of the device:
74LS273@18E_analyzing
Once desoldered the device failed when tested out-of-circuit:
74LS273@18E_failed
I got  improvements, now backgorunds were almost formed but still scrambled and sprites visible although not perfect:
With my HP10529A I found a 74LS157 with floating outputs @17D on CPU board:
74LS157@14D
Chip failed the out-of-circuit test:
74LS157@14D_failed
Backgrounds were now 100% restored but sprites missing lines with some garbage on screen :
At this point I focused on video board since all objects circuitry lies there :
100_8611
Probing around the sprites EPROMs, I found a 74LS367 @1F with bad outputs:
74LS367@1F_
and a 7LS257 @3C (involved in sprites RAM data bus) with stuck outputs, also this failed its test:
74LS257@3C_
Now sprites were perfect but doing some comparison with MAME I realized that characters were totally missing!
Found a 74LS257 @14G with missing input pin 15 (/OE  ) in the area of the character ROM:
74LS257@14G
I traced it back to an output of a 74LS367@20B on CPU board:
74LS367@20BJPG
Logic analyzing confirmed its outputs were floating and chip failed once tested out-of-circuit:
74LS367@20B
Characters were back:
fixed_2
I was archiving this repair when, during my test,  I experienced some sound issues, sometimes audio was distorted:
This board uses an YM3526 OPL IC paired with an YM3014 DAC although chips are marked with Nichibutsu part name (‘TC 148509’ and ‘TC 1409’) :
100_8687
Probing pin 2 (the analog output connected to the OP-AMP) of the ‘TC 1409’ revealed a weak signal:
100_8690
I replaced it with a YM3014 :
TC1409_reworking
This gave good sound back.Board 100% fixed and evil Fujitsu once again defeated.
100_8696
 Posted by at 11:26 pm
  One Response to “Terra Cresta repair log #1”
  1. Nice work. TC is one of my all-time favs.
