Jun 042017
Having a working Terra Cresta bootleg (from Tecfri but they are all the same) gave me the opportunity to verify the PAL dumps we had.I successfully converted from PAL16R4 to GAL16V8 fuse map two of them.The third one was a native dump from a PAL16L8, the fuse map we had was not good so I redumped the device from my board and successfully reversed it in GAL16V8.Most likely, like it often happen for bootlegs that have same layout of original, the dumps should be working also on the Nichibutsu board but a real test is needed and would be appreciated.
