Jan 122015
Welcome to my first repair log!
I bought this (very) expensive pcb from ebay in October 2014.
I played the game a couple of times and then after about one week, all the sprites disappeared while I was playing. Only background and text were present:
Foto 22-10-14 20 52 25
I couldn’t believe, at first I began to press everywhere hoping it was a loose or oxydized connector but soon I realized something got faulty.
This game hasn’t any schematics available so I knew from the beginning it would have been very tough to fix it.
I connected my trusty logic probe and began to short some pins on the pcb to see what changed on the screen so that I could focus on the right part of the circuit.
Foto 29-10-14 23 30 26
After about 30 mins turned on, the sprites started to reapper but missing some lines:
Foto 29-10-14 23 07 33
I then remembered that 1942 hardware is very similar to Son Son and the schematics are available.
I was right, the way that TTL chips are connected on 1942 is equal on Son Son. Only the positions of the ICs are different but the logic is really similar.
I probed the 2148 rams @F2 and @F4 on Son Son pcb which on 1942 schematics are described as OBJ rams and I found a stuck /WR signal @F4 on Son Son (J4 on 1942):
son2
I followed back the signal always taking a look on 1942 schematics, and I found finally the source of the problems on the missing signal on pin 11 of an 74LS00 @F11 (on 1942 I circled the equivalent IC @K11).
OnΒ  1942 schematics available on internet, someone circled the 74LS00@N8 writing “no plane”, probably he had the same fault. πŸ˜‰
son1
Foto 29-10-14 23 27 24
Replacing the 74LS00@F11 gave me back all the sprites
Foto 29-10-14 23 29 25
  One Response to “Son Son repair log”
  1. The fist repair log is ..like the first love, you’ll never forget it! Well done, Corrado! πŸ™‚
