Oct 302014
Today I’ve added to our database two of the three PALs dumps (the one stamped ‘315-5394’ is registered) coming from an original Sega Columns PCB.These PALs should be present on all games that run on Sega System C/C2 hardware.Dumps are tested and working on a GAL16V8 targeting device.Just a technical note : the PAL marked ‘315-5395’ was manually reversed by Porchy (thanks to him!) since it has latches built-in.If you want to go into that, I recommend reading this document about PLDs:
