Feb 062015
Today I had the chance to try the existing PAL dump of the PAL16R4 marked ‘315-5138’ @IC11 on a Sega System 2 Shooting Master PCB and I can confirm it’s working also on this board (so it’s not exclusive to Choplifter).Besides, I converted in GAL16V8 format the MAME dump of the other PAL16R4 ‘315-5137’ @IC10 and tested it as good.Finally, I converted the ‘315-5139’ PLS153 dump made by Porchy into CK2605 original device fusemap using the Charles MacDonald PLAD utility and then successfully reversed it to GAL16V8 format.Database has been updated.
